[postgis-users] What is SRID 999155
Paul Norman
penorman at mac.com
Fri Oct 2 15:29:04 PDT 2020
SRIDs above 999000 are reserved by PostGIS. The main use I've seen for
them is with _ST_BestSRID as part of area or length calculations. Most
of them are equivalent to EPSG codes that are normally in
spatial_ref_sys. For example, 999000 is equivalent to EPSG:3395, but the
latter may not be present on a system. You can see what they are in
https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/libpgcommon/lwgeom_transform.h
and the proj4 text is in
https://git.osgeo.org/gitea/postgis/postgis/src/branch/master/libpgcommon/lwgeom_transform.c.
On 2020-10-02 6:17 a.m., Imre Samu wrote:
> >> PostGIS references SRID 999155.
> > That feels like a bug. File and line number?
> As I see the "not public" _ST_BestSRID return this.
> select _ST_BestSRID(ST_Point(147,-60));
> _st_bestsrid
> 999155
> (1 row)
> ( via https://github.com/postgis/postgis/search?q=999155 )
> Imre
> Greg Troxel <gdt at lexort.com <mailto:gdt at lexort.com>> ezt írta
> (időpont: 2020. okt. 2., P, 13:22):
> Simon G Greener <simon at spatialdbadvisor.com
> <mailto:simon at spatialdbadvisor.com>> writes:
> > What is it? It is not listed on reference.org
> <http://reference.org>.
> I find no trace of it.
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201002/da8c206a/attachment.html>
