[postgis-users] shp import through GDAL fails
Regina Obe
lr at pcorp.us
Tue Oct 13 08:22:59 PDT 2020
> this was my initial guess, that's why I'm asking here (Postgis 3, that is).
> Thanks.
> Il 13/10/20 16:21, b.j.kobben at utwente.nl ha scritto:
> > I think the function AddGeometryColumnis deprecated already for some
> > time (now should be ST_AddGeometryColumn)so maybe in postgis v13 it
> > does not work anymore...
> Paolo Cavallini
> www.faunalia.eu - QGIS.org
> training, support, development on QGIS, PostGIS and more
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
The function is AddGeometryColumn. AddGeometryColumn still exists. http://postgis.net/docs/manual-3.0/AddGeometryColumn.html
We have never had nor will we ever have a ST_AddGeometryColumn
So to Darafei's point, make sure you are connected to a database with PostGIS installed and also make sure the schema PostGIS is installed in is in the database search path.
Also make sure the account you are using in QGIS is does not have search_path overridden.
Thanks,
Regina
