[postgis-users] Ynt: pg_restore: error: could not execute query: ERROR: function public.st_accum(public.geometry) does not exist
Bekir Niyaz bagafoot at hotmail.com
Fri Oct 16 01:21:10 PDT 2020
Thank you Regina,
>Did you install PostGIS on 2.5.2 using scripts or extension?  Those functions shouldn’t even be in your backup if you used an extension install.
Yes I used extension install
>It could however be complaining about references in your code to those.
There is no any code, or function created by developer, only postgis functions.
>Do not drop postgis 2.5.2 as that would drop your geometry and raster columns.
If there is columns depend on postgis, should be error on droping extension, right ? But I easily can drop extension. May it hint to solution?
ERROR:  cannot drop extension postgis because other objects depend on it
DETAIL:  column geo of table tbl_sapmle depends on type geometry
HINT:  Use DROP ... CASCADE to drop the dependent objects too.
>CREATE EXTENSION postgis_raster;  -- raster was broken out of the postgis extension in 3.0
>That should fix the raster errors.
Yes, total errors had decreased. All errors about grants cannot find functions
Command was: GRANT ALL ON FUNCTION public._st_distance(public.geography, public.geography, double precision, boolean) TO cedyetrapor_app;GRANT ALL ON FUNCTION public._st_distance(public.geography, public.geography, double precision, boolean) TO test_user;
other errors:
pg_restore: error: could not execute query: ERROR:  function public._st_asgeojson(integer, public.geography, integer, integer) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_asgeojson(integer, public.geometry, integer, integer) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_asgml(integer, public.geography, integer, integer, text, text) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_askml(integer, public.geography, integer, text) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_askml(integer, public.geometry, integer, text) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_buffer(public.geometry, double precision, cstring) does not exist
pg_restore: error: could not execute query: ERROR:  function public._st_distance(public.geography, public.geography, double precision, boolean) does not exist
>In your old database try to find in your views (I’m guessing might be where it’s coming from) reference to ST_Accum use  -- and change them to use array_agg instead.
You mean functions here ?, because there is only default postgis views
 public | geography_columns | view | postgres
 public | geometry_columns  | view | postgres
 public | raster_columns    | view | postgres
 public | raster_overviews  | view | postgres
Thank you again for your atention.
Best regards.
Gönderen: Regina Obe <lr at pcorp.us> adına postgis-users <postgis-users-bounces at lists.osgeo.org>
Gönderildi: 15 Ekim 2020 Perşembe 11:28
Kime: 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
Konu: Re: [postgis-users] pg_restore: error: could not execute query: ERROR: function public.st_accum(public.geometry) does not exist
If you can’t upgrade the old to 3.0, do the following on new
ST_Accum was removed in 3.0 as it’s redundant and less performant than PostgreSQL built in array_agg
Hope that helps,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Bekir Niyaz
Sent: Thursday, October 15, 2020 4:07 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] pg_restore: error: could not execute query: ERROR: function public.st_accum(public.geometry) does not exist
I 'm trying restore backup from pg11 postgis 2.5.2 to pg12 postgis 3.0.0, but restore failing.
If I drop postgis 2.5.2 on source server and install 3.0.0 will It cause the problem ?
details:
source db (where backup taken):
     PostgreSQL 11.1 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-28), 64-bit
     POSTGIS="2.5.2 r17328" [EXTENSION] PGSQL="110" GEOS="3.7.1-CAPI-1.11.1 27a5e771" PROJ="Rel. 4.9.3, 15 August 2016" GDAL="GDAL
    1.11.4, released 2016/01/25" LIBXML="2.9.1" LIBJSON="0.11" RASTER
target db (where restore):
     PostgreSQL 12.4 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-39), 64-bit
     POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 " SFCGAL="1.3.1" PROJ="6.2.1" LIBXML="2.9.1" LIBJSON="0
    .11" LIBPROTOBUF="1.0.2" WAGYU="0.4.3 (Internal)" TOPOLOGY
 dump file:
      Dump Version: 1.14-0
      Format: CUSTOM
      Integer: 4 bytes
      Offset: 8 bytes
      Dumped from database version: 11.1
      Dumped by pg_dump version: 12.1
example errors:
    Command was: GRANT ALL ON FUNCTION public.st_accum(public.geometry) TO test_app;
    pg_restore: error: could not execute query: ERROR:  type "public.raster" does not exist
    Command was: GRANT ALL ON FUNCTION public.st_countagg(public.raster, boolean) TO test_app;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201016/65b59f83/attachment.html>
