[postgis-users] breake lines
Alexandre Neto
senhor.neto at gmail.com
Tue Oct 27 04:39:47 PDT 2020
Hello Paul,
It seems that, at least, one geometry in the data table is not correctly
defined.
Use this to confirm:
SELECT geom, ST_Geometrytype(geom)
FROM data;
Best regards,
Alexandre Neto
QGIS/PostGIS Support
www.cooperative.net
On Tue, Oct 27, 2020 at 9:40 AM <paul.malm at lfv.se> wrote:
> Hi I would like to break lines in intersections of polygons, but without
> erasing anything.
> I have used this (but now suddenly, it does not work) :
> Create table tmpint2 as
> WITH
> data AS (
> SELECT * FROM public."linesToBeCut" AS t(id, geom)
> cutter AS (
> SELECT * FROM "cutterPolygons" AS t(geom)
> SELECT id,
> CASE WHEN cutting IS NULL THEN geom
> ELSE st_collectionExtract(ST_Split( geom, cutting ),2) END AS geom
> FROM (SELECT id, d.geom geom,
> (SELECT ST_Collect(c.geom) geom
> FROM cutter c WHERE ST_Intersects(d.geom, c.geom)
> ) AS cutting
> FROM data d) AS t;
> The error code I get is :
> st_intersects(integer, geometry) does not exsits
> Can anyone please tell me what I’m doing wrong here. I’m not to bright in
> SQL.
> /Paul
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201027/7c586f9e/attachment.html>
