[postgis-users] Bizarre behavior with postgis function as part of where clause!
Bo Guo
bo.guo at gisticinc.com
Fri Sep 4 20:27:44 PDT 2020
Hi List,
I just ran into a pretty bizarre query behavior involving simple queries
involving PostGIS functions as part of where clause condition.
I have two geometries in table tmp_test_geoms , one point and a line:
ST_Point "0101000000806FE29BC53B2241800FDDE3E9C53341"
ST_LineString
"010200000005000000E072B95C215A22412033C40C65963341401C0E074D5A22412097CB056E963341809821E6235E22412033C48C6D963341A027E909BA5F22410087C3E16E963341C0B2AEACD95F224100FCFDFE71963341"
Both Query 1 and Query 2 fails w/ message "Argument to ST_X() must have
type POINT," Query 3 works however
1. SELECT ST_GeometryType(geom) gtype, geom FROM tmp_test_geoms
WHERE ST_GeometryType(geom) = 'ST_Point' AND ST_X(geom) > 1;
2. WITH foo AS (SELECT ST_GeometryType(geom) gtype, geom FROM
tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point')SELECT * FROM
foo WHERE ST_X(geom) > 1;
3. WITH foo AS (SELECT ST_GeometryType(geom) gtype, geom FROM
tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point' LIMIT 10)SELECT
* FROM foo WHERE ST_X(geom) > 1;
It seems that the query engine evaluates ST_X first before applying the
GeometryType filter, even when the filter is in a CTE.
It further seems that by adding LIMIT with an arbitrary value at the end
of the CTE, the filter is applied first!
Wonder if there is a way to give some type of query hint to force the
evaluation sequences.
Thanks for any suggestions!
Bo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200904/b3426aa2/attachment.html>
