[postgis-users] Bizarre behavior with postgis function as part of where clause!
Bo Guo
bo.guo at gisticinc.com
Sat Sep 5 21:10:06 PDT 2020
Hi, "offset 0" in CTE worked. I later used CASE-CLAUSE to avoid using
CTE and worked as well. Cheers!
SELECT ST_GeometryType(geom) gtype, geom FROMtmp_test_geoms WHERECASE WHEN ST_GeometryType(geom) = 'ST_Point' THEN ST_X(geom) < 1 ELSE
FALSE END;
On 9/5/20 11:14 AM, Regina Obe wrote:
> Or I forgot to mention, I think the old hack of OFFSET like you have
> in 3 still works and for backward compatibility would be preferable
> over using the MATERIALIZED keyword, but less clear in intent
> So something
> WITH foo AS (SELECT ST_GeometryType(geom) gtype, geom FROM
> tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point' OFFSET 0)
> SELECT * FROM foo WHERE ST_X(geom) > 1;
> *From:*Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Saturday, September 5, 2020 2:12 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Subject:* RE: [postgis-users] Bizarre behavior with postgis function
> Have you tried adding a MATERIALIZED to your WITH? In PostgreSQL 12
> and above, CTEs are no longer always materialized.
> e.g.
> WITH foo AS MATERIALIZED (SELECT ST_GeometryType(geom) gtype, geom
> FROM tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point') SELECT *
> This article describes it a bit
> https://paquier.xyz/postgresql-2/postgres-12-with-materialize/
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Bo Guo
> *Sent:* Friday, September 4, 2020 11:28 PM
> *To:* postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] Bizarre behavior with postgis function as
> Hi List,
> I just ran into a pretty bizarre query behavior involving simple
> queries involving PostGIS functions as part of where clause condition.
> I have two geometries in table tmp_test_geoms , one point and a line:
> ST_Point "0101000000806FE29BC53B2241800FDDE3E9C53341"
> ST_LineString
> "010200000005000000E072B95C215A22412033C40C65963341401C0E074D5A22412097CB056E963341809821E6235E22412033C48C6D963341A027E909BA5F22410087C3E16E963341C0B2AEACD95F224100FCFDFE71963341"
> Both Query 1 and Query 2 fails w/ message "Argument to ST_X() must
> have type POINT," Query 3 works however
> 1. SELECT ST_GeometryType(geom) gtype, geom FROM tmp_test_geoms
> WHERE ST_GeometryType(geom) = 'ST_Point' AND ST_X(geom) > 1;
> 2. WITH foo AS (SELECT ST_GeometryType(geom) gtype, geom FROM
> tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point') SELECT * FROM
> 3. WITH foo AS (SELECT ST_GeometryType(geom) gtype, geom FROM
> tmp_test_geoms WHERE ST_GeometryType(geom) = 'ST_Point' LIMIT 10)
> It seems that the query engine evaluates ST_X first before applying
> the GeometryType filter, even when the filter is in a CTE.
> It further seems that by adding LIMIT with an arbitrary value at the
> end of the CTE, the filter is applied first!
> Wonder if there is a way to give some type of query hint to force the
> evaluation sequences.
> Thanks for any suggestions!
> Bo
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
Regards,
Bo Guo, PhD, PE
President
Gistic Research, Inc.
2033 E Warner Rd Ste 105
Tempe, AZ 85284
www.gisticinc.com
www.youtube.com/linearbench
Office: 480-656-9962
Cell: 602-570-4697
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200905/f78ec286/attachment.html>
