[postgis-users] ST_AsMVTGeom AND table name as parameter in pl/psql
James McManus jmpmcmanus at gmail.com
Wed Sep 16 07:31:33 PDT 2020
I'm trying to develop a plpgsql function that would extract mapbox vector
tiles from a postgresql/post gis database. The database has multiple
geospatial tables, so I want the function to be able to take a table name
as a parameter.
I've gotten the function to work using hard coded table names. Discussion
on functions with table name as a parameter say I need to use EXECUTE.
However, when I try and use EXECUTE in the mvtgeom AS section of the script
I get a syntax error on EXECUTE:
CREATE OR REPLACE
FUNCTION public.region3_sim_storms_pg(z integer, x integer, y integer,
stormtable text)
RETURNS bytea
AS $$
DECLARE
  result bytea;
BEGIN
  WITH
  bounds AS (
    SELECT ST_TileEnvelope(z, x, y) AS geom
  mvtgeom AS (
     EXECUTE format(
       'SELECT ST_AsMVTGeom(ST_Transform(G.geom, 3857), bounds.geom, 4096,
256, true) AS geom, node, bathymetry
        FROM %s AS G, bounds
        WHERE ST_Intersects(G.geom, ST_Transform(bounds.geom, 4326))',
quote_ident(stormtable)
  SELECT ST_AsMVT(mvtgeom, 'public.region3_sim_storms_pg')
  INTO result FROM mvtgeom;
  RETURN result;
END
LANGUAGE 'plpgsql'
STABLE
PARALLEL SAFE;
COMMENT ON FUNCTION public.region3_sim_storms_pg IS 'Given a tile address,
storm name query database.';
Past discussion on this topic says this error occurs because the function
is not being recognized as a plpgsql function, but I have LANGUAGE
'plpgsql' specified. The only thing I can think of is that things are
reverted back to SQL in the "mvtgeom AS (" portion of the script. Is there
a way to use EXECUTE in the "mvtgeom AS (" portion of the script?
Thanks
Jim
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200916/2815d7a1/attachment.html>
