[postgis-users] ST_AsMVTGeom AND table name as parameter in pl/psql
James McManus
jmpmcmanus at gmail.com
Wed Sep 16 09:38:44 PDT 2020
I did not need "INTO result" in:
SELECT ST_AsMVT((mvtgeom, %s)
INTO result FROM mvtgeom;', z, x, y, quote_ident(stormtable),
quote_literal('public.region3_sim_storms_pg')
changes it to:
and it worked!
Thanks!
Jim
On Wed, Sep 16, 2020 at 12:28 PM James McManus <jmpmcmanus at gmail.com> wrote:
> That's what I am currently struggling with. My current code is:
> CREATE OR REPLACE
> FUNCTION public.region3_sim_storms_pg(z integer, x integer, y integer,
> stormtable text)
> RETURNS bytea
> AS $$
> DECLARE
> result bytea;
> BEGIN
> EXECUTE format(
> 'WITH
> bounds AS (
> SELECT ST_TileEnvelope(%s, %s, %s) AS geom
> mvtgeom AS (
> SELECT ST_AsMVTGeom(ST_Transform(G.geom, 3857), bounds.geom,
> 4096, 256, true) AS geom, node, bathymetry
> FROM %s AS G, bounds
> WHERE ST_Intersects(G.geom, ST_Transform(bounds.geom, 4326))
> SELECT ST_AsMVT(mvtgeom, %s)
> INTO result;
> RETURN result;
> END
> LANGUAGE 'plpgsql'
> VOLATILE
> PARALLEL SAFE;
> COMMENT ON FUNCTION public.region3_sim_storms_pg IS 'Given a tile address,
> storm name query database.';
> When I run it I get:
> =# SELECT * FROM region3_sim_storms_pg(13,2361,3138,'r3sim_fort_geom');
> ERROR: EXECUTE of SELECT ... INTO is not implemented
> HINT: You might want to use EXECUTE ... INTO or EXECUTE CREATE TABLE ...
> AS instead.
> CONTEXT: PL/pgSQL function
> region3_sim_storms_pg(integer,integer,integer,text) line 5 at EXECUTE
> On Wed, Sep 16, 2020 at 12:16 PM Nicolas Ribot <nicolas.ribot at gmail.com>
> wrote:
>> (and you can still store the result in a variable with the construct
>> EXECUTE 'your query here' into result;)
>> nicolas
>> On Wed, 16 Sep 2020 at 16:40, Nicolas Ribot <nicolas.ribot at gmail.com>
>> wrote:
>>> Hi,
>>> You have to enclose the whole query into a string and execute it, not
>>> just only the second CTE (mvtgeom).
>>> It should be:
>>> BEGIN
>>> EXECUTE format('WITH bounds as ( ....', ...)
>>> Nicolas
>>> On Wed, 16 Sep 2020 at 16:32, James McManus <jmpmcmanus at gmail.com>
>>> wrote:
>>>> I'm trying to develop a plpgsql function that would extract mapbox
>>>> vector tiles from a postgresql/post gis database. The database has multiple
>>>> geospatial tables, so I want the function to be able to take a table name
>>>> as a parameter.
>>>> I've gotten the function to work using hard coded table names.
>>>> Discussion on functions with table name as a parameter say I need to use
>>>> EXECUTE. However, when I try and use EXECUTE in the mvtgeom AS section of
>>>> the script I get a syntax error on EXECUTE:
>>>> CREATE OR REPLACE
>>>> stormtable text)
>>>> RETURNS bytea
>>>> AS $$
>>>> DECLARE
>>>> result bytea;
>>>> BEGIN
>>>> WITH
>>>> bounds AS (
>>>> SELECT ST_TileEnvelope(z, x, y) AS geom
>>>> mvtgeom AS (
>>>> EXECUTE format(
>>>> 'SELECT ST_AsMVTGeom(ST_Transform(G.geom, 3857), bounds.geom,
>>>> WHERE ST_Intersects(G.geom, ST_Transform(bounds.geom, 4326))',
>>>> SELECT ST_AsMVT(mvtgeom, 'public.region3_sim_storms_pg')
>>>> RETURN result;
>>>> END
>>>> LANGUAGE 'plpgsql'
>>>> STABLE
>>>> PARALLEL SAFE;
>>>> address, storm name query database.';
>>>> Past discussion on this topic says this error occurs because the
>>>> function is not being recognized as a plpgsql function, but I have LANGUAGE
>>>> 'plpgsql' specified. The only thing I can think of is that things are
>>>> reverted back to SQL in the "mvtgeom AS (" portion of the script. Is there
>>>> a way to use EXECUTE in the "mvtgeom AS (" portion of the script?
>>>> Thanks
>>>> Jim
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200916/3c54e77e/attachment.html>
