[postgis-users] Setting multiple columns in one UPDATE request
Marco Boeringa
marco at boeringa.demon.nl
Sun Sep 27 00:28:34 PDT 2020
Hi all,
This may be an irrelevant basic question, but I just cannot find a clear
answer to this, there is no documentation in the PostgreSQL docs for
UPDATE about this:
In case I set multiple columns using some PostGIS function that clearly
has a (considerable) cost associated with it, and the value of the first
column being set is also needed to set the second column, does
PostgreSQL automatically optimize this and re-use the value already
calculated for column 1 to set column 2's value, or is each column's SET
statement treated as independent entity?
E.g. let's say I want to calculate both area, and the division of area
and perimeter, like:
UPDATE <MY_TABLE> SET area = ST_Area(<GEOMETRY_COLUMN>), area_perimeter
= ST_Area(<GEOMETRY_COLUMN>) / ST_Perimeter(<GEOMETRY_COLUMN>)
Will PostgreSQL only process 'ST_Area(<GEOMETRY_COLUMN>)' once in this
case, thus saving CPU load, or do I need to rewrite the SQL statement
somehow to achieve that?
Marco
