[postgis-users] Setting multiple columns in one UPDATE request - Additional results for large polgyons.
Marco Boeringa
marco at boeringa.demon.nl
Wed Sep 30 00:03:48 PDT 2020
Hi Regina,
I now did a second test with two datasets of forest polygons, to get an
indication if the subquery has any measurable positive effect on such a
dataset, contrary to the previously shown result for a dataset primarily
consisting of low vertex count (<200) polygons (results included in the
older posts attached below).
The first dataset has records with geometries of up to about 100k
vertices, the second dataset is a generalized one with all polygons
subdivided to a maximum of 5000 vertices.
The results are included below. As you can see, using a subquery still
does not lead to a real measurable performance gain, neither for the
dataset with humongous big polygons, nor the one with subdivided
polygons containing a large set of 5000 max vertices polygons. Only the
single threaded result on the first dataset with max 100k vertices per
polygon, appears to have a tiny measurable gain, but considering the
slight variability of timing results at each run even with the same
settings, I am pretty sure even this is not significant.
What is significant compared to the previous results of a dataset with
small polygons (majority < 200 vertices per polygon), is that the
multi-threaded processing is considerably faster than the single
threaded processing. So processing is clearly CPU limited for these
larger polygons, but whether that is really in the PostGIS calculations,
or overhead of PostgreSQL needing to de-toast large polygons, I don't know.
It does appear though, that PostgreSQL somehow already manages to
"optimize" the calculations reusing calculated values, unless the cost
of ST_Area and ST_Perimeter calculations on really large polygons is
still only a fraction of the reading and writing of the geometries, in
which case the results of the query processing simply do not show the
inherent cost difference of the different queries.
Note though, that although I showed:
UPDATE <MY_TABLE> SET area = ST_Area(<GEOMETRY_COLUMN>), area_perimeter
= ST_Area(<GEOMETRY_COLUMN>) / ST_Perimeter(<GEOMETRY_COLUMN>)
as an example query to illustrate the problem, the timing results are
actually for an UPDATE statement setting 4 columns that all need
'ST_Area()' as part of the calculation. So in reality, the potential
benefits of the rewriting of the query, should have been even bigger
than for the example query above, as the polygon's area is needed four
times.
Marco
*** Dataset with very large polygon geometries (Max 100k vertices) *********
- Single-threaded using ORIGINAL QUERY: 32m05s
- Single-threaded using SUBQUERY (FROM): 31m52s
- Multi-threaded using ORIGINAL QUERY: 18m16s
- Multi-threaded using SUBQUERY (FROM): 18m46s
*** Dataset SUBDIVIDED to polygons with max 5000 vertices! *********
- Single-threaded using ORIGINAL QUERY: 11m01s
- Single-threaded using SUBQUERY (FROM): 11m11s
- Multi-threaded using ORIGINAL QUERY: 5m37s
- Multi-threaded using SUBQUERY (FROM): 5m46s
Op 28-9-2020 om 18:28 schreef Regina Obe:
> ST_Area and ST_Perimeter functions are relatively low cost, so that
> fact you discovered is not surprising.
> I think if you were doing something like ST_Distance then the CTE or
> subquery would be more efficient than your direct solution.
> *From:*postgis-users [mailto:postgis-users-bounces at lists.osgeo.org]
> *On Behalf Of *Marco Boeringa
> *Sent:* Monday, September 28, 2020 10:15 AM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* Re: [postgis-users] Setting multiple columns in one UPDATE
> request
> Hi Regina,
> I can now partially answer my question about performance myself:
> It turns out that for datasets having relatively small geometries (in
> terms of number of vertices, not area, e.g. a few dozen to a few
> hundred vertices maximum) there is actually *NO* benefit at all of
> rewriting the query either with a WITH (CTE) or FROM (Subquery). This
> may be different though for other datasets having much larger
> geometries, but needs further testing.
> In fact, processing is marginally slower, but only by 5-10% or so,
> compared to the original query.
> In my setup, I can also run the query both in a single thread, or
> using a custom Python multi-threaded implementation sending SQL
> statements in parallel to PostgreSQL. Since the test system has a very
> limited 4 core multi-threaded processor, the benefits of the
> multi-threading versus single threaded processing in this case are
> nil, obviously due to the overhead of the multi-threading. The
> multi-threaded application is as fast as the single threaded
> PostgreSQL worker, or even a bit slower, but puts a far higher load on
> the processor. Of course, with a more modern processor with high core
> count, this experience likely changes.
> There also appears to be virtually no difference between using a CTE
> or the subquery as you suggested: subquery is only very marginally
> faster than CTE.
> So for datasets having small geometries, just sticking to the original
> query like:
> area_perimeter = ST_Area(<GEOMETRY_COLUMN>) /
> is fine for those datasets.
> I think this result is caused by the fact that the retrieving and
> storing overhead of the geometries (tables stored on SSD), is simply
> far bigger than the actual cost of calculating the area or perimeter
> for such datasets where the majority of geometries is of very limited
> size (e.g. OSM buildings, simple landuse polygons). Additionally,
> there may be an extra cost due to the needed join for the CTE and
> subquery statements. Lastly, the cost of running ST_Area and
> ST_Perimeter may just be to low as well. There may be other functions
> in PostGIS with a much higher computational cost that would show a
> benefit from rewriting the query.
> I will attempt to run a second benchmark using a dataset with much
> larger geometries though (some with well over > 10k vertices), to see
> if that gives the same result, and report back. There may be a
> difference, but we will see...
> Marco
> *** Dataset with small geometries (most < 200 vertices) *********
> - Single-threaded using ORIGINAL QUERY: 8m45s
> - Single-threaded using SUBQUERY (FROM): 8m52s
> - Single-threaded using CTE (WITH): 9m13s
> - Multi-threaded using ORIGINAL QUERY: 9m27s
> - Multi-threaded using SUBQUERY (FROM): 9m44s
> - Multi-threaded using CTE (WITH): 9m50s
> Op 28-9-2020 om 09:36 schreef Marco Boeringa:
> Regina,
> Thanks for your suggestion.
> How is this performance wise? Is not using a CTE as in your
> suggestion, supposedly faster than with using a CTE, or is this
> just a syntax thing and performance is expected to be equal?
> It would still be nice though, if PostgreSQL somehow handled this
> automatically, and one could use the most basic form yet be sure
> it was optimized. It also reads more easily to just see:
> in your code, instead of more elaborate construct involving a join.
> Marco
> Op 28-9-2020 om 03:26 schreef Regina Obe:
> I prefer doing it in the FROM and not bothering using a CTE.
> So something like
> UPDATE <MY_TABLE> SET area = f.area, area_perimeter = f.area/f.perimeter
> FROM (SELECT id, ST_Area(<GEOMETRY_COLUMN>) AS area, ST_Perimeter(<GEOMETRY COLUMN>) AS perimeter
> FROM <MY TABLE> ) AS f
> WHERE f.id = <MY TABLE>.id;
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20200930/7587ea73/attachment.html>
