[postgis-users] Has anyone tried GML to table?
Simon G Greener simon at spatialdbadvisor.com
Wed Sep 30 20:20:55 PDT 2020
There is a small mistake in the SQL I supplied.
The SQL is more easily accessible on my website at:
https://www.spdba.com.au/processing-gml-data-using-postgresqls-xmltable/
This is corrected section:
SELECT decoded.room_id,
        decoded.capacity,
        decoded.comment,
*       ST_AsEWKT(**
**          ST_GeomFromGML(decoded.location::text,4326)**
**       ) as geom*
FROM
     hoteldata
     cross join
     xmltable(
         '//hotels/hotel/rooms/room'
         passing hotels
         COLUMNS
             room_id  varchar(3) path '@id',
*            location xml        path 'location/Point',*
             capacity integer,
             comment  text
     ) AS decoded;
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20201001/c75ddc13/attachment.html>
