[postgis-users] linux failed postgis 3.1.1 compile against proj 8.0.0 (could not find libproj)
Donovan Cameron sault.don at gmail.com
Sat Apr 3 16:30:23 PDT 2021
Thanks, should of tried that already instead of my hackery patching....
using stable-3.1 does the trick =)
On 2021-04-03 3:07 p.m., Paul Ramsey wrote:
> 3.1.1 doesn't include the proj8 fix, the 3.1.2 release will. You can
> use the front of the stable-3.1 branch or the front of main branch.
> P.
> On Sat, Apr 3, 2021 at 1:23 PM Saulteau Don <sault.don at gmail.com
> <mailto:sault.don at gmail.com>> wrote:
>     I'm building on arch linux and trying to see if postgis 3.1.1 will
>     compile against proj 8.0.0 and get  "error: could not find libproj
>     - you may need to specify the directory of a PROJ installation
>     using --with-projdir"
>     Looks like it's possible to build against postgis 3 with proj 8 [1]
>     The patch [2] isn't in the 3.1.1 release so I applied it and also
>     used the --with-projdir=/usr option but get same error.
>     OS: Linux archasus 5.11.11-arch1-1 #1 SMP PREEMPT Tue, 30 Mar 2021
>     14:10:17 +0000 x86_64 GNU/Linux
>     PostGIS: 3.1.1
>     PROJ: 8.0.0
>     Some of the configure log is below but have uploaded the entire
>     log to my drive [3]:
>         | #include <proj_api.h>
>         configure:16973: result: no
>         configure:16973: checking for proj_api.h
>         configure:16977: checking proj.h usability
>         configure:16977: gcc -c -std=gnu99 -march=native -O2 -pipe
>         -fstack-protector-strong -fno-plt -fno-math-errno
>         -fno-signed-zeros -I/usr/include conftest.c >&5
>         configure:16977: $? = 0
>         configure:16977: result: yes
>         configure:16977: checking proj.h presence
>         configure:16977: gcc -E -I/usr/include conftest.c
>         configure:16977: checking for proj.h
>         configure:16993: checking for proj.h
>         configure:16993: result: yes
>         configure:17028: gcc -o conftest -std=gnu99 -march=native -O2
>         -pipe -fstack-protector-strong -fno-plt -fno-math-errno
>         -fno-signed-zeros -I/usr/include -Wl,-O1,
>         --sort-common,--as-needed,-z,relro,-z,now -lm conftest.c  >&5
>         configure:17028: $? = 0
>         configure:17028: ./conftest
>         configure:17108: checking for pj_get_release in -lproj
>         configure:17133: gcc -o conftest -std=gnu99 -march=native -O2
>         -fno-signed-zeros -D_FORTIFY_SOURCE=2 -Wl
>         ,-O1,--sort-common,--as-needed,-z,relro,-z,now -lm conftest.c
>         -lproj  -L/usr/lib -lproj >&5
>         /usr/bin/ld: /tmp/cclmEHNm.o: in function `main':
>         conftest.c:(.text.startup+0x8): undefined reference to
>         `pj_get_release'
>         collect2: error: ld returned 1 exit status
>         configure:17133: $? = 1
>         configure: failed program was:
>         | /* confdefs.h */
>         | #define PACKAGE_NAME ""
>         | #define PACKAGE_TARNAME ""
>         | #define PACKAGE_VERSION ""
>         | #define PACKAGE_STRING ""
>         | #define PACKAGE_BUGREPORT ""
>         | #define PACKAGE_URL ""
>         | #define STDC_HEADERS 1
>         | #define HAVE_SYS_TYPES_H 1
>         | #define HAVE_SYS_STAT_H 1
>         | #define HAVE_STDLIB_H 1
>         | #define HAVE_STRING_H 1
>         | #define HAVE_MEMORY_H 1
>         | #define HAVE_STRINGS_H 1
>         | #define HAVE_INTTYPES_H 1
>         | #define HAVE_STDINT_H 1
>         | #define HAVE_UNISTD_H 1
>         | #define HAVE_DLFCN_H 1
>         | #define LT_OBJDIR ".libs/"
>         | #define POSTGIS_MAJOR_VERSION "3"
>         | #define POSTGIS_MINOR_VERSION "1"
>         | #define POSTGIS_MICRO_VERSION "1"
>         | #define YYTEXT_POINTER 1
>         | #define HAVE_IEEEFP_H 0
>         | #define HAVE_TERMIOS_H 1
>         | #define HAVE_VASPRINTF 1
>         | #define HAVE_ASPRINTF 1
>         | #define HAVE_FSEEKO 1
>         | #define HAVE_ICONV 1
>         | #define PGSQL_LOCALEDIR "/usr/share/locale"
>         | #define HAVE_LIBPQ 1
>         | #define POSTGIS_PGSQL_VERSION 130
>         | #define POSTGIS_PGSQL_HR_VERSION 13.0
>         | #define HAVE_LIBXML_TREE_H 1
>         | #define HAVE_LIBXML_PARSER_H 1
>         | #define HAVE_LIBXML_XPATH_H 1
>         | #define HAVE_LIBXML_XPATHINTERNALS_H 1
>         | #define HAVE_LIBXML2 1
>         | #define POSTGIS_LIBXML2_VERSION "2.9.10"
>         | #define HAVE_LIBGEOS_C 1
>         | #define POSTGIS_GEOS_VERSION 39
>         | #define POSTGIS_SFCGAL_VERSION 10309
>         | #define HAVE_SFCGAL 1
>         | #define ENABLE_NLS 1
>         | #define HAVE_GETTEXT 1
>         | #define HAVE_DCGETTEXT 1
>         | #define POSTGIS_PROJ_VERSION 80
>         | /* end confdefs.h.  */
>         | /* Override any GCC internal prototype to avoid an error.
>         |    Use char because intmight match the return type of a GCC
>         |    builtin and then its argument prototype would still
>         apply.  */
>         | #ifdef __cplusplus
>         | extern "C"
>         | #endif
>         | char pj_get_release ();
>         | int
>         | main ()
>         | return pj_get_release ();
>         |   return 0;
>         configure:17142: result: no
>         configure:17152: error: could not find libproj - you may need
>         to specify the directory of a PROJ installation using
>         --with-projdir
>     SaultDon
>     [1] https://trac.osgeo.org/postgis/ticket/4860
>     <https://trac.osgeo.org/postgis/ticket/4860>
>     [2]
>     https://github.com/postgis/postgis/commit/9522a6f869ee6d170d97e7c593d7e5d71ec02a9b
>     <https://github.com/postgis/postgis/commit/9522a6f869ee6d170d97e7c593d7e5d71ec02a9b>
>     [3]
>     https://drive.google.com/file/d/16FupiGJD69O75iW2eGAIErXuM-ncuP1p/view?usp=sharing
>     <https://drive.google.com/file/d/16FupiGJD69O75iW2eGAIErXuM-ncuP1p/view?usp=sharing>
>     _______________________________________________
>     postgis-users mailing list
>     postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/postgis-users
>     <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210403/ac4054ee/attachment.html>
