[postgis-users] possible problem with PostGIS on RHEL8
Worth Lutz
wal3 at mindspring.com
Thu Apr 22 13:34:27 PDT 2021
Hi Paul,
We are trying to get MapServer and PostGIS installed on RHEL8.2. We
have had problems with multiple versions of proj and gdal getting
installed which is causing the MapServer to link to both and crash.
We are having a hard time finding a version of PostGIS to install which
does not have Proj8 as MapServer is not ready for that yet.
I think I have found a inconsistency in the gdal32-libs builds.
Here is what I'm looking at:
postgis31_13-3.1.1-1.rhel8.x86_64.rpm This uses proj >= 7.2.1
& gdal-libs >= 3.2.1 and should work for MapServer
gdal32-3.2.2-12.rhel8.x86_64.rpm to meet the above
requirement - requires gdal32-libs = 3.2.2-12.rhel8
gdal32-libs-3.2.2-*12*.rhel8.x86_64.rpm *here is the problem* -
requires proj80 >= 8.0
When I look at gdal32-libs-3.2.2-*13*.rhel8.x86_64.rpm it also requires
proj8.
I see no earlier version of gdal like v3.2.1 so I expected one of the
gdal-libs above to use proj 7 and the other to use proj8. Am I wrong to
expect that? Or am I missing something?
Can you point me to the correct postGIS to use with MapServer on RHEL8?
Or to someone who might have a solution?
Thanks,
*Worth Lutz*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210422/d5f70684/attachment.html>
