[postgis-users] ST_Split precision issue?
Martin Davis
mtnclimb at gmail.com
Fri Apr 30 12:45:34 PDT 2021
It would probably be helpful if ST_Split was enhanced to have this same
behaviour (i.e. split at the closest point along the line).
On Fri, Apr 30, 2021 at 12:27 PM Martin Davis <mtnclimb at gmail.com> wrote:
> For working with points and lines it's probably better to use the linear
> referencing functions. Here's a query which does what you require:
> WITH line(geom) AS (VALUES
> ('LINESTRING(8.39567520433486 49.4224277276901,8.39591232763397
> 49.4198517063953)'::geometry)
> SELECT ST_AsText(
> ST_LineSubstring( geom, 0, ST_LineLocatePoint(geom,
> 'POINT(8.39583178549713 49.4207266868819)'::geometry))
> ) AS part1,
> ST_AsText(
> ST_LineSubstring( geom, ST_LineLocatePoint(geom, 'POINT(8.39583178549713
> 49.4207266868819)'::geometry), 1)
> ) AS part2
> FROM line;
> On Sun, Apr 25, 2021 at 7:49 AM Nicol Hermann <postgis at geoworld.de> wrote:
>> Hello List,
>> I am trying to split a linestring at an intersection to another line
>> into it's two segments.
>> This works as expected with "dummy" coordinates, but fails with "real-
>> world" coordinates.
>> This:
>> SELECT ST_AsText( ST_Split (ST_GeomFromText('LINESTRING(0 0,2 2)'),
>> ST_GeomFromText('POINT(1 1)') ) ) as lsegments;
>> gives me the expected output:
>> lsegments
>> GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(1 1,2 2))
>> (1 Zeile)
>> When I am trying this with real world coordinates I am always getting
>> the un-splitted original linesting back.
>> Sample:
>> SELECT ST_AsText(ST_intersection(aline, bline)) AS
>> wktcut
>> FROM (SELECT
>> ST_GeomFromText('LINESTRING(8.39567520433486
>> 49.4224277276901,8.39591232763397 49.4198517063953)') As aline,
>> ST_GeomFromText('LINESTRING(8.39481293779266
>> 49.4206708596104,8.39717339245195 49.4208001995917)') As bline ) As
>> foo;
>> returns
>> If I am using this in the split command
>> (ST_GeomFromText('LINESTRING(8.39567520433486
>> 49.4224277276901,8.39591232763397 49.4198517063953)'),
>> ST_GeomFromText('POINT(8.39583178549713 49.4207266868819)') ) ) as
>> lsegments;
>> the result is
>> lsegments
>> GEOMETRYCOLLECTION(LINESTRING(8.39567520433486
>> 49.4224277276901,8.39591232763397 49.4198517063953))
>> (1 Zeile)
>> which es equal to the input.
>> Is this a precision issue between differen postgis functions and how
>> can I solve this?
>> If I'am adding ST_Snap it returns a linestring which only represents
>> one of the 2 segments I would expect.
>> See:
>> SELECT
>> ST_AsText(
>> ST_Split (
>> ST_Snap (
>> ST_GeomFromText('POINT(8.39583178549713 49.4207266868819)'), 1 ),
>> as lsegments;
>> response is:
>> lsegemts
>> 49.4224277276901,8.39583178549713 49.4207266868819))
>> Any hints, or do I have a misconception how ST_Split should work?
>> Thanks
>> Nicol
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210430/b35c3b4a/attachment.html>
