[postgis-users] Installing pgdg Postgis 3.1 on CentOS/Rhel7 breaks sqlite3 cli
Josiah Ulfers
josiah.ulfers at nltgis.com
Fri Aug 20 14:17:40 PDT 2021
Thanks, even if there turns out to be no good fix, I filed for posterity:
https://redmine.postgresql.org/issues/6702
-----Original Message-----
From: postgis-users <postgis-users-bounces at lists.osgeo.org> On Behalf Of
Paul Ramsey
Sent: Wednesday, August 18, 2021 5:41 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] Installing pgdg Postgis 3.1 on CentOS/Rhel7
breaks sqlite3 cli
RPM build issues should be filed with the pdgd redmine
https://redmine.postgresql.org/projects/pgrpms/
I'm not sure there's a good fix for the problem though...
replacing/removing the old version is not allowed for the new package
because the new package is not system-wide, it's part of the attempt by
pgdg to vendor in specific versions while leaving the system (mostly)
alone.
P
