[postgis-users] make failing postgis-3.1.3dev for CENTOS 7
Raj Talati rajtalati at gmail.com
Tue Aug 31 14:03:53 PDT 2021
Hello,
I was able to run the configure finally with the option to download
proj/geos and other latest packages to get support for MVT. Not sure what I
am missing here ? Is there a full RPM package for 3.1.3 with MVT Support
for CENTOS 7 ? as normal PostGIS yum install doesn't allow MVT functions .
make had same error
So ran make - i  ( To ignore error )
make check gives the same error so i guess will not work .
Ran configure with options  :
./configure --with-pgconfig=/usr/pgsql-13/bin/pg_config
--with-geosconfig=/apps/geos/geos-3.9.1/tools/geos-config
--with-protobuf-inc=/usr/local/include/google/protobuf-c
--with-protobufdir=/apps/protobuf/protobuf-c-master/protobuf-c
-with-protobuf-lib=/usr/local/lib
 --with-gdalconfig=/usr/gdal32/bin/gdal-config
config.log last few lines output
#define PGSQL_LOCALEDIR "/usr/pgsql-13/share/locale"
#define HAVE_LIBPQ 1
#define POSTGIS_PGSQL_VERSION 130
#define POSTGIS_PGSQL_HR_VERSION 13.0
#define HAVE_LIBXML_TREE_H 1
#define HAVE_LIBXML_PARSER_H 1
#define HAVE_LIBXML_XPATH_H 1
#define HAVE_LIBXML_XPATHINTERNALS_H 1
#define HAVE_LIBXML2 1
#define POSTGIS_LIBXML2_VERSION "2.9.1"
#define HAVE_LIBGEOS_C 1
#define POSTGIS_GEOS_VERSION 39
#define ENABLE_NLS 1
#define HAVE_GETTEXT 1
#define HAVE_DCGETTEXT 1
#define POSTGIS_PROJ_VERSION 81
#define HAVE_LIBPROJ 1
#define HAVE_LIBPROTOBUF_C 1
#define HAVE_PROTOBUF_C_VERSION 1
#define HAVE_LIBPROTOBUF 1
#define LIBPROTOBUF_VERSION 1004000
#define PARANOIA_LEVEL 0
#define POSTGIS_VERSION "3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
#define POSTGIS_LIB_VERSION "3.1.3dev"
#define POSTGIS_BUILD_DATE "2021-08-31 19:43:37"
#define POSTGIS_SCRIPTS_VERSION "3.1.3dev"
#define POSTGIS_RASTER_WARN_ON_TRUNCATION 0
#define POSTGIS_GDAL_VERSION 32
#define HAVE_GDAL_H 1
#define HAVE_OGR_API_H 1
#define HAVE_CPL_CONV_H 1
#define HAVE_CXX11 1
#define HAVE_WAGYU 1
configure: exit 0
v # make check
! find . -name '*.c' -o -name '*.h' -o -name '*.proto' | \
        grep -v lwin_wkt_lex.c | \
        grep -v lwin_wkt_parse | \
        grep -v lookup3 | \
        grep -v vector_tile.pb-c | \
        grep -v postgis/sqldefines.h | \
        grep -v deps/ | \
        xargs grep -n '[[:space:]]$'
/usr/bin/perl utils/repo_revision.pl
fatal: Not a git repository (or any parent up to mount point /apps)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Can't determine revision from git log
Not updating existing rev file at fd0cef4
for s in liblwgeom libpgcommon postgis regress raster topology  loader
utils doc extensions deps; do \
        echo "---- Making all in ${s}"; \
        make -C ${s} all || exit 1; \
done;
---- Making all in liblwgeom
make[1]: Entering directory `/apps/postgis/postgis-3.1.3dev/liblwgeom'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/apps/postgis/postgis-3.1.3dev/liblwgeom'
---- Making all in libpgcommon
make[1]: Entering directory `/apps/postgis/postgis-3.1.3dev/libpgcommon'
make[1]: Leaving directory `/apps/postgis/postgis-3.1.3dev/libpgcommon'
---- Making all in postgis
make[1]: Entering directory `/apps/postgis/postgis-3.1.3dev/postgis'
/usr/bin/protoc-c --c_out=. vector_tile.proto
vector_tile.proto:21:13: Expected "required", "optional", or "repeated".
vector_tile.proto:21:30: Missing field number.
make[1]: *** [vector_tile.pb-c.c] Error 1
make[1]: Leaving directory `/apps/postgis/postgis-3.1.3dev/postgis'
make: *** [all] Error 1
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210831/a521e17b/attachment.html>
