[postgis-users] Is there a generic function to find coincident vertex?
Shaozhong SHI
shishaozhong at gmail.com
Thu Dec 2 16:34:20 PST 2021
Hip, Simon,
Many thanks. I will try to test out soon.
I find postgis most amazing.
Regards, David
On Friday, 3 December 2021, Simon G Greener <simon at spatialdbadvisor.com>
wrote:
> Not that I am aware.
> You could try wrapping something like the following SQL in a function....
> with data as (
> select 0.01 as tolerance,
> ST_GeomFromText('LINESTRING(0 0 1.1,1 1.001 1.2,1 1.0005
> 1.3,1 1 1.1,2 2 1.2)',0) as geom
> select SUM(isDuplicate) as duplicateCount
> from (select case when ST_Distance(ST_PointN(a.geom,
> b.*),lead(ST_PointN(a.geom,b.*)) over (order by b.*)) < a.tolerance
> then 1
> else 0
> end as isDuplicate
> from data as a,
> generate_series(1,ST_NumPoints(a.geom),1) as b
> ) as f;
> Note that if the linestring was a compoundCurve repeated vertices are part
> of the definition.
> regards
> Simon
> On 3/12/2021 9:46 am, Shaozhong SHI wrote:
> Is there a generic function to find coincident vertex and count?
> It will do the following:
> Create an array of all vertex present in a data set
> Iterate over and find out whether there be any coincident vertex as
> defined by a tolerance
> Count all occurrences
> Regards,
> David
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211203/6e2c988c/attachment.html>
