[postgis-users] Trace network from each source node and check that the trace reaches the sea
Stephen V. Mather
svm at clevelandmetroparks.com
Thu Dec 30 15:28:50 PST 2021
Hi David,
This is a good example. I have modified this to walk networks before,
and it's a minimal and understandable example:
http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html
There may be some better ways to do this, as the postgres tooling has
changed quite a bit. The use of a function may be precluded by some
modern fancy join type. Others can speak better to that than I can these
days.
Also, if you don't mind installing one more thing, pgrouting will do
network traversal much more efficiently than a /WITH RECURSIVE/ network
traversal:
https://pgrouting.org/
Cheers,
Best,
Steve
On 12/30/21 4:13 PM, Shaozhong SHI wrote:
> *WARNING: This email originated outside of Cleveland Metroparks. DO
> NOT CLICK links or attachments unless you recognize the sender and
> know the content is safe.*
> In hydrological network, how to trace network from each source node
> and check whether the trace can reach the sea?
> Any examples?
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211230/47b01f48/attachment.html>
