[postgis-users] Trace network from each source node and check that the trace reaches the sea
Shaozhong SHI
shishaozhong at gmail.com
Thu Dec 30 16:03:29 PST 2021
Hi, Steve,
I cannot see the pictures.
Regards,
David
On Thu, 30 Dec 2021 at 23:36, Stephen V. Mather <svm at clevelandmetroparks.com>
wrote:
> Hi David,
> This is a good example. I have modified this to walk networks before, and
> it's a minimal and understandable example:
> http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html
> There may be some better ways to do this, as the postgres tooling has
> changed quite a bit. The use of a function may be precluded by some modern
> fancy join type. Others can speak better to that than I can these days.
> Also, if you don't mind installing one more thing, pgrouting will do
> network traversal much more efficiently than a *WITH RECURSIVE* network
> traversal:
> https://pgrouting.org/
> Cheers,
> Best,
> Steve
> On 12/30/21 4:13 PM, Shaozhong SHI wrote:
> *WARNING: This email originated outside of Cleveland Metroparks. DO NOT
> CLICK links or attachments unless you recognize the sender and know the
> content is safe.*
> In hydrological network, how to trace network from each source node and
> check whether the trace can reach the sea?
> Any examples?
> Regards,
> David
> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211231/1ab373c1/attachment.html>
