[postgis-users] PostGIS "Subdivide" should insert vertex where subdivision lines intersect
Marco Boeringa
marco at boeringa.demon.nl
Wed Feb 24 02:08:21 PST 2021
Hi all,
I don't know how much of an effort it would be, but I think it would be
nice if PostGIS's "Subdivide" was enhanced to insert a vertex where
subdivision lines "intersect". Currently, when a large shape is
subdivided, if a vertical sudivide line "hits" a horizontal one, the
sub-part of the large geometry being subdivided that is above or below
the horizontal subdivision line, won't receive a vertex where the
vertical subdivision line "hits" it.
This has the negative consequence that as soon as you start reprojecting
the geometries resulting of this subdivide operation to another
projection and depending on that projection's properties, e.g. with
on-the-fly projection in QGIS, that the three geometries around this
"virtual" intersection of subdivision lines, won't match, and show a
clearly visible gap.
This could be prevented if "Subdivide" always inserted an extra vertex
at the intersection of the subdivision lines, even if the geometry part
above or below the horizontal subdivision line, won't be cut vertically
at that point.
Marco
