[postgis-users] PostGIS Raster: Two Questions
Simon SPDBA Greener
simon at spdba.com.au
Tue Mar 16 17:15:17 PDT 2021
I have a 1 band raster, srid 4326, (0.001 x 0.001 roughly 100m x 100m) ,
called *gbr100x100d*, whose pixels are coded 0 and 1 where 1 is water
deeper than 100m and 0 water shallower than 100m.
It was created as follows:
*create table gbr100x100d
as
SELECT row_number() over (order by 1) as rid,
ST_SetSrid(ST_MapAlgebra(a.rast, 1, NULL,
'([rast.val]<-100.0)::integer'),4326) as rast
from gbr100x100c as a;*
First question: how can one recode *gbr100x100d *so that all pixels with
value 0 are NODATA?
Next.
Polygons of size 0.02x 0.01 need to be extracted from the 1 valued 0.001
pixels.
I think this should be done as follows.
First we resample to get a raster with cells of size 0.02 x 0.01:
*create table gbr2kmx1kmd1**
**as**
**SELECT row_number() over (order by 1) as rid,**
**ST_SetSrid(ST_Rescale(a.rast,0.02,-0.01,'Bilinear',0.125),4326) as rast**
** from gbr100x100d as a;**
Then we extract the polygons of these 0.02 x 0.01 pixels.
*create table gbr2kmx1kmd1p**
**as **
**SELECT row_number() over (order by 1) as id, (gv).val,
ST_SnapToGrid((gv).geom,0.001)::geography as geog**
** FROM (SELECT ST_PixelAsPolygons(a.rast,1,true) as gv **
** FROM gbr2kmx1kmd1 as a**
** ) gv**
** WHERE (gv).val = 1;*
The result is close as the polygons are 0.02 x 0.01 but they are
organised as a set of striped polygons where the columns don't touch.
See attached.
What was expected was a complete coverage of abutting polygons.
Can anyone spot what I am doing wrong?
regards
Simon
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210317/c7673e6f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20210317/c7673e6f/attachment.png>
