[postgis-users] pgsql2shp can't handle WITH
Jonathan Schultz jonathan at schultz.la
Sat Nov 6 05:10:46 PDT 2021
Hello,
While attempting to use pgsql2shp with some queries I found that it
seems to struggle with WITH clauses. For a trivial example:
 > $ pgsql2shp ... "WITH foo AS (SELECT 2) SELECT 1"
 > Table WITH foo AS (SELECT 2) SELECT 1 does not exist
whereas psql handles the same query as expected:
 > $ psql ... -c "WITH foo AS (SELECT 2) SELECT 1"
>  ?column?
>         1
> (1 row)
Can anyone shed some light on this?
Thanks,
Jonathan
