[postgis-users] PROJ_LIB environment variable
Wisse J.S. (Jeroen)
js.wisse at zeeland.nl
Wed Nov 17 05:45:26 PST 2021
We have a server that has multiple versions of PostgreSQL installed.
Some of these PostgreSQL installations use the PostGIS extension. Unfortunately these PostGIS extensions are all different versions.
When using the windows installer for PostGIS some environment variables are set. Some can have the same value for each PostGIS installation. But there are 2 that refer to a specific directory.
These are:
- GDAL_DATA: which also can be set in the postgresql.conf file as postgis.gdal_datapath
- PROJ_LIB
My question is, is it possible to set the PROJ_LIB variable somewhere else then as an environment variable?
Kind regards,
Jeroen Wisse
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211117/0f797771/attachment.html>
