[postgis-users] PostgreSQL 13, PostGIS 3.1 import - could not form projection
karsten karsten at terragis.net
Fri Oct 15 11:46:44 PDT 2021
Yes will try to get this to work and report back here.
The stack exchange issue mentioned that it worked with an older gdal version
so will try with both different proj and gdal combinations
Karsten
-----Original Message-----
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf
Of Paul Ramsey
Sent: Friday, October 15, 2021 11:36
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL 13, PostGIS 3.1 import - could not
form projection
There's something very particular about your environment and I don't know
what it is. Try upgrading your proj version, and jimmying with other version
combinations. There's nothing special about the SRID numbers, they work fine
for me locally. I can't invest the time in setting up a mirror system that
matches yours. If there's something specific about proj 6.3.1 maybe? (both
you and the stack exchange issue)
P
> On Oct 15, 2021, at 11:11 AM, karsten <karsten at terragis.net> wrote:
> Hi All,
> on new server with Ubuntu 20.04 , PostgreSQL 13, PostGIS 3.1 I am
> trying to import a plain sql dump . This mostly worked but when the
> script is executing the creation of a geohash (involving a
> transformation from srid 2263 to geographic 4326) like this
> CREATE INDEX parcels_geohash ON parcels USING btree
> (st_geohash(st_transform(geom, 4326)));
> I am getting this error:
> could not form projection (PJ) from 'srid=2263' to 'srid=4326'
> How can I fix this ?
> Here are more details about the environment:
> postgres: PostgreSQL 13.4 (Ubuntu 13.4-4.pgdg20.04+1) on
> x86_64-pc-linux-gnu, compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04)
> 9.3.0, 64-bit
> postgis_version: 3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> postgis_proj_version: 6.3.1
> Cheers
> Karsten
> Karsten Vennemann
> www.terragis.net
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
