[postgis-users] ST_DWithin question
Marco Boeringa
marco at boeringa.demon.nl
Fri Oct 22 05:04:47 PDT 2021
Thanks Arnaud,
This is a very useful answer. I will try the ST_Intersects option you
propose.
Minor correction to the link provided, which should read:
https://gis.stackexchange.com/questions/400700/st-intersects-vs-st-dwithin-behavior-on-polygons-using-postgis
Marco
Op 22-10-2021 om 13:52 schreef Arnaud L.:
> Hi Marco
> Le 22/10/2021 à 13:31, Marco Boeringa a écrit :
>> I currently use the following two queries. This first query creates a
>> table with all unique 'pairs' of polygons as identified by their ID
>> using 'ST_DWithin with a 0 range from the <MY_TABLE1> original polygon
>> table. The second one deduplicates the two columns of the first table to
>> create a unique list of IDs.
> I think I would write this in a single query, using an EXISTS subquery
> instead of a join step and a dedup step :
> SELECT tbl.id
> FROM <MYTABLE1> AS tbl
> WHERE EXISTS (
> SELECT 1
> FROM <MYTABLE1> AS subq
> WHERE subq.id != tbl.id AND ST_Intersects(tbl.<GEOMETRY_COLUMN> ,
> subq.<GEOMETRY_COLUMN>)
> No need to DISTINCT or anything here, the result should already be
> correct.
>> From the documentation of
>> ST_DWithin, it is clear it is already optimized to use the spatial index
>> and bounding boxes to speed up the search, so I guess there is nothing
>> more I can do. It is properly using multiple parallel workers in
>> PostgreSQL as well for creating the table from a look in PgAdmin.
> ST_DWithin(a,b,0) is logically equivalent to ST_Intersects(a,b), but
> as per this post on SE, ST_Intersects might be faster due to internal
> optimizations :
> https://gis.stackexchange.com/questions/400700/st-intersects-vs-st-dwithin-behavior-on-polygons-using-postgiseo.org/mailman/listinfo/postgis-users
> Regards
> Arnaud
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20211022/b7ad378f/attachment.html>
