[postgis-users] my server return OK with ALL, but QUERY.test from HOME http://postgis.net return ERROR
Gary Turner
g at elizr.com
Sun Sep 12 16:09:57 PDT 2021
Does your database on your server contain that data?
That is just an example, it won't work if you don't have the correct
data in those tables on your server.
On 13/09/2021 2:54 am, cPanel cPanel wrote:
> hello
> I have 4 results from QUERYS in my CentOs 7 + PostgreSQL 13.4 on
> x86_64-pc-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat
> 4.8.5-44), 64-bit
> I connect as USER postgres
> QUERY 1:
> SELECT PostGIS_Version();
> => 3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> QUERY 2:
> SELECT PostGIS_Full_Version();
> => POSTGIS="3.1.4 ded6c34" [EXTENSION] PGSQL="130"
> GEOS="3.9.1-CAPI-1.14.2" SFCGAL="1.3.1" PROJ="7.2.1" GDAL="GDAL 3.3.1,
> released 2021/06/28" LIBXML="2.9.1" LIBJSON="0.11" TOPOLOGY RASTER
> QUERY 3:
> SELECT num, street, city, state, zip FROM parse_address('1 Devonshire
> Place PH301, Boston, MA 02109');
> [num] => 1
> [street] => Devonshire Place PH301
> [city] => Boston
> [state] => MA
> [zip] => 02109
> now my problem in QUERY 4:
> a// I open http://postgis.net/
> b// I copy exactly "the command test" from home page:
> QUERY = SELECT superhero.name FROM city, superhero WHERE
> ST_Contains(city.geom, superhero.geom) AND city.name = 'Gotham';
> c// I run QUERY in my server
> d// result is:
> [pg_last_error()] => ERROR: relation "city" does not exist
> LINE 1: SELECT superhero.name FROM city, superhero WHERE ST_Contains...
> why this error?
> how I can fix?
> my target is OTHERS users (not postgres) can use POSTGS
> then how can user1, user2, user33 use POSTGIS without connect to DB postgres ??
> or... to use POSTGIS is mandatory users connect to postgres DB ?
> many thanks
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
