[postgis-users] LinestringM with one point
Poul Bondo poul.bondo at gmail.com
Tue Sep 21 07:32:23 PDT 2021
Hello
We have been using postgis for the past 7-8 years for storing a lot of
ship tracks in PostgreSQL.
We are storing the data with one record per vessel per day as
geography(linestringm) of position reports with a timestamp in the M part.
In many cases we only have one position per day and thus have stored a
linestringm with length = 1.
Until now this has not caused problems.
In the documentation for the upcoming PostGIS 3.2.0 a new section has
been added including the statement:
"A LineString must have at least two points." and by extension we assume
this will be the case for linestringM also
Also we discovered a problem when using replication which uses COPY in
some cases which works fine and INSERT which does not work in other
cases when using linestringM with length = 1
Is there a significant reason for having / adding this requirement and
if so are there any recommendation on how to handle the scenario with
only one sample?
Thanks
Poul
