[postgis-users] ST_Transform weirdness in 3.1.5
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 4 10:01:42 PDT 2022
Not super obvious as I'm not seeing a reproduction here on a more recent proj. Anyone with proj6 able to reproduce?
P
> On Apr 4, 2022, at 9:18 AM, Jeff Hoffmann <jeff at propertykey.com> wrote:
> I am running PostgreSQL via Amazon RDS. Here is the version
> information for the instance that exhibits the problem:
>                                                   version
> PostgreSQL 12.8 on aarch64-unknown-linux-gnu, compiled by
> aarch64-unknown-linux-gnu-gcc (GCC) 7.4.0, 64-bit
> (1 row)
> postgis_full_version
> POSTGIS="3.1.5 0" [EXTENSION] PGSQL="120" GEOS="3.8.2-CAPI-1.13.4"
> PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12.99" LIBPROTOBUF="1.3.0"
> WAGYU="0.5.0 (Internal)"
> (1 row)
> Here is an example of a query that produces weird results:
> select st_asewkt(st_transform('SRID=4269;POLYGON((-81.11425169432798
> 25.139365690162226,-79.88375846050846
> 25.135204935817377,-79.8759485474324
> 25.97511821217247,-81.11505127181294
> 25.97943803781699,-81.11425169432798 25.139365690162226))'::geometry,
> 3087));
>        st_asewkt
> SRID=3087;POLYGON((690648.3378382007 129676.3544158864,Infinity
> Infinity,Infinity Infinity,688388.1492655604
> 222840.53520809134,690648.3378382007 129676.3544158864))
> (1 row)
> Two of the points are coming up as (Infinty,Infinity).  When I run the
> same query using the proj4text found in the spatial_ref_sys table
> instead of the srid I get the following output:
> '+proj=aea +lat_1=24 +lat_2=31.5 +lat_0=24 +lon_0=-84 +x_0=400000
> +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs'));
>                     st_asewkt
> POLYGON((690648.3378382007 129676.3544158864,814558.219082916
> 132733.37665360732,812229.019377012
> 225881.33726899035,688388.1492655604
> (1 row)
> This looks pretty close to right.  What is the disconnect between
> using the srid to call the transform vs the proj4text version of
> st_transform?
> Jeff Hoffmann
> PropertyKey
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
