[postgis-users] ST_Transform weirdness in 3.1.5
Paul Ramsey pramsey at cleverelephant.ca
Mon Apr 4 10:58:28 PDT 2022
Yeah, at a first approximation, the obvious reason for the problem is "with an EPSG code, proj can try and do a smart datum conversion via grids, whereas with only a proj string, proj is stuck doing a naive bursa-wolf transformation, hence your problem". However, that would still leave open "why Inf?" and "how do I stop this?". So if anyone has a reproducing environment, would be interested to know.
P.
> On Apr 4, 2022, at 10:56 AM, Jeff Hoffmann <jeff at propertykey.com> wrote:
> Thanks at least for looking into this.  One other thing I just
> noticed: If I transform from EPSG:4269 -> EPSG:4326 first, it seems to
> work as expected.
> select st_asewkt(st_transform('SRID=4326;POLYGON((-81.11425169432798
> 25.139365690162226,-79.88375846050846 25.97,-79.8759485474324
> 25.97511821217247,-81.11505127181294
> 25.97943803781699,-81.11425169432798 25.139365690162226))'::geometry,
> 3087));
>                          st_asewkt
> SRID=3087;POLYGON((690648.4490696276
> 129676.1163013646,811467.6067641322 225287.6132890527,812229.019377012
> 225881.33726899035,688387.9040682416
> 222840.47302733874,690648.4490696276 129676.1163013646))
> (1 row)
> I have another server configured as follows (also v6.2.1 of PROJ) that
> works fine, one of the differences is the postgis version, which is
> why I asked about whether it could be a postgis problem.
>                                             version
> PostgreSQL 12.4 on x86_64-pc-linux-gnu, compiled by
> x86_64-pc-linux-gnu-gcc (GCC) 7.4.0, 64-bit
> (1 row)
> postgis_full_version
> POSTGIS="3.0.2 2fb2a18" [EXTENSION] PGSQL="120"
> GEOS="3.8.1-CAPI-1.13.3" PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12.99"
> LIBPROTOBUF="1.3.0" WAGYU="0.4.3 (Internal)"
> (1 row)
> Could this be something with the proj configuration? Does calling
> ST_Transform using an SRID use some sort of internal proj
> configuration that may be weird or does it pull the proj4text from the
> spatial_ref_sys table? There are other differences that make this
> weird (big one is the weird server is on ARM, everything else is x86)
> so as much as anything I'm just trying to figure out where to start
> looking if nothing else.
> On Mon, Apr 4, 2022 at 12:01 PM Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Not super obvious as I'm not seeing a reproduction here on a more recent proj. Anyone with proj6 able to reproduce?
>> P
>>> On Apr 4, 2022, at 9:18 AM, Jeff Hoffmann <jeff at propertykey.com> wrote:
>>> I am running PostgreSQL via Amazon RDS. Here is the version
>>> information for the instance that exhibits the problem:
>>>                                                  version
>>> PostgreSQL 12.8 on aarch64-unknown-linux-gnu, compiled by
>>> aarch64-unknown-linux-gnu-gcc (GCC) 7.4.0, 64-bit
>>> (1 row)
>>> POSTGIS="3.1.5 0" [EXTENSION] PGSQL="120" GEOS="3.8.2-CAPI-1.13.4"
>>> PROJ="6.2.1" LIBXML="2.9.9" LIBJSON="0.12.99" LIBPROTOBUF="1.3.0"
>>> WAGYU="0.5.0 (Internal)"
>>> (1 row)
>>> Here is an example of a query that produces weird results:
>>> select st_asewkt(st_transform('SRID=4269;POLYGON((-81.11425169432798
>>> 25.135204935817377,-79.8759485474324
>>> 3087));
>>>       st_asewkt
>>> SRID=3087;POLYGON((690648.3378382007 129676.3544158864,Infinity
>>> Infinity,Infinity Infinity,688388.1492655604
>>> 222840.53520809134,690648.3378382007 129676.3544158864))
>>> (1 row)
>>> Two of the points are coming up as (Infinty,Infinity).  When I run the
>>> same query using the proj4text found in the spatial_ref_sys table
>>> instead of the srid I get the following output:
>>> '+proj=aea +lat_1=24 +lat_2=31.5 +lat_0=24 +lon_0=-84 +x_0=400000
>>> +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs'));
>>>                    st_asewkt
>>> POLYGON((690648.3378382007 129676.3544158864,814558.219082916
>>> 132733.37665360732,812229.019377012
>>> 225881.33726899035,688388.1492655604
>>> (1 row)
>>> This looks pretty close to right.  What is the disconnect between
>>> using the srid to call the transform vs the proj4text version of
>>> st_transform?
>>> Jeff Hoffmann
>>> PropertyKey
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
> Jeff Hoffmann
> Head Plate Spinner
> PropertyKey
> Office: 612-800-6444
