[postgis-users] A table of DE-9IE patterns and types of topological relations
Martin Davis
mtnclimb at gmail.com
Mon Apr 18 19:55:00 PDT 2022
Good to hear. I did run it through an online color accessibility checker,
so I guess that has worked out.
On Mon, Apr 18, 2022 at 7:20 PM Jim Klassen <klassen.js at gmail.com> wrote:
> It looks a lot better to me.
> On 4/18/22 16:52, Martin Davis wrote:
> Is this any better?
> https://postgis.net/docs/manual-dev/using_postgis_query.html#DE-9IM
> On Mon, Apr 18, 2022 at 2:31 PM Jim Klassen <klassen.js at gmail.com> wrote:
>> As an aside, I am noticing these graphics probably aren't very accessible
>> to people with vision impairments. There is a lack of meaningful alt-text,
>> a general fuzziness/soft edges, and use of several colors of similar
>> lightness. In particular, the red is hard to separate out in grayscale and
>> the red is the part that is most important as it is describing the part of
>> the image that applies to that grid cell.
>> I'm not sure if it will come through on the list, but I've converted the
>> 3x3 grid image from [1] to grayscale below as an example. I know I'd have
>> a very hard time picking out which section was what if I didn't already
>> know the answer ahead of time.
>> [1] https://postgis.net/workshops/postgis-intro/_images/de9im3.jpg
>> On 4/15/22 15:08, Shaozhong SHI wrote:
>> This is very interesting.
>> However, this needs to be further detailed with a table to explain a
>> variety of cases and uses.
>> Regards,
>> David
>> On Fri, 15 Apr 2022 at 02:48, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> https://postgis.net/workshops/postgis-intro/de9im.html
>>> > On Apr 14, 2022, at 4:35 PM, Shaozhong SHI <shishaozhong at gmail.com>
>>> wrote:
>>> > The use of ST_Relate appears very attractive. However, there appears
>>> not yet a table detailing DE_9IE patterns and types of topological
>>> relations.
>>> > There also appears that not much literature on the use of it for data
>>> quality assurance or things like deriving quality data from raw data.
>>> > Can anyone enlighten me?
>>> > Regards,
>>> > David
>>> > _______________________________________________
>>> > postgis-users mailing list
>>> > postgis-users at lists.osgeo.org
>>> > https://lists.osgeo.org/mailman/listinfo/postgis-users
>> postgis-users mailing listpostgis-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220418/03d5fa2a/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220418/03d5fa2a/attachment.png>
