[postgis-users] PostGis introduction doc code block seems wrong....
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Thu Apr 21 12:53:25 PDT 2022
It might have something to do with implicit transactional behaviour, (
START TRANSACTION;/commands/; COMMIT).
Anyway, another little tidbit to remember
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 21-04-2022 kl. 17:32 skrev Paul Ramsey:
> Well now that you mention it, it does seem funky, and I have no idea what the expected behavour is...
> create table foo (old text, new text);
> insert into foo (old) values ('1234');
> update foo set old = left(old, 2), new = old
> where old = '1234';
> select * from foo;
> I'm going to go out on a limb and suggest that maybe the values on the right-hand side of the assignment are actually always implicitly from the original record, so in trigger terms, the assignments look like NEW.colname = OLD.colname.
> P
>> On Apr 21, 2022, at 2:12 AM, Bo Victor Thomsen<bo.victor.thomsen at gmail.com>  wrote:
>> Am I the only one that get "semantic itch" looking at the UPDATE expression? I would prefer it like this:
>> UPDATE nyc_neighborhoods
>>    SET geom_invalid = geom,
>>        geom = ST_MakeValid(geom)
>>    WHERE NOT ST_IsValid(geom);
>> where you save the original "geom" value into another column "geom_invalid" before rectifying it and saving it into the original column.
>> Disclaimer: I have no clue about the internal methods of the SQL interpreter and how and in which order it assigns values.
>> Bo Victor Thomsen
>> Den 20-04-2022 kl. 16:59 skrev Regina Obe:
>>> Thanks for the errata.  Corrected now.
>>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Jian He
>>> Sent: Wednesday, April 20, 2022 5:12 AM
>>> To: PostGIS Users Discussion<postgis-users at lists.osgeo.org>
>>> Subject: [postgis-users] PostGis introduction doc code block seems wrong....
>>> 23. Validity — Introduction to PostGIS
>>> last code block,
>>> -- Fix invalid and save the original
>>>    SET geom = ST_MakeValid(geom),
>>>        invalid_geom = geom
>>> I think it should be:
>>>        geom_invalid = geom
>>> postgis-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220421/952ae22f/attachment.html>
