[postgis-users] Configuration and performance of PostGIS
Marco Boeringa
marco at boeringa.demon.nl
Thu Apr 21 23:17:57 PDT 2022
You are comparing apples and pears.
From a quick scan at the links you posted, the LineCombiner does a
fundamentally different thing than the "network-walking" example, it
simply "combines" any line connected to any other line at its end
vertex, which is not the same as "network-walking". This is more like a
PostGIS "ST_Collect()" operation, that also doesn't care about network
connectivity.
By the way, I never see PostgreSQL take full CPU (2x14 core
workstation), even with PostgreSQL configured to allow as many CPU cores
for parallel operations as there are physically. I wish it did, it would
speed up some operations that really need it. The only way I can get
full CPU usage is through a custom build Python multi-threading
framework putting PostgreSQL and PostGIS to work.
Maybe your server is underpowered for the type of work you wish to do.
Marco
Op 22-4-2022 om 01:19 schreef Shaozhong SHI:
> Whenever geospatial functions such as St_intersects or recursive query
> used, the PostGIS appears to spawn away to many child queries and just
> obliterate the CPU. Nothing finishes.
> That forced me to try out to do the some tasks on the FME server.
> I tried to use this
> http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html
> <http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html> in
> the PostGIS.
> I tried to linecombiner in FME. LineCombiner | FME (safe.com)
> <https://www.safe.com/transformers/line-combiner/>.
> With a large data set, the running of processors were monitored. It
> was estimated the PostGIS one would take 16 days to complete.
> But, it only took a few minute to do the same thing in FME.
> This suggests that something is not right with the PostGIS Server.
> Have anyone got experience with configuration and improving perfomance
> of PostGIS Server?
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220422/7f283319/attachment.html>
