[postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Regina Obe
lr at pcorp.us
Tue Aug 30 15:56:17 PDT 2022
Marcelo,
Apologies, this file was left out in my packaging. I’ll create an updated package later this week to fix this issue and will also have a 3.3.0 which doesn’t have this issue.
I’ve updated ticket to reflect.
Copy the attached file (which is essentially an empty file) into your
C:\Program Files\PostgreSQL\11\share\extension folder
And then try your upgrade again.
Sorry for the omission,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Marcelo Marques
Sent: Tuesday, August 30, 2022 6:08 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Hello,
I am trying to get a workaround for the problem below.
see more details in this link
https://trac.osgeo.org/postgis/ticket/5222#ticket
Have you encountered this issue before? If yes, do you know how to fix it ?
Thanks,
| Marcelo Marques | Esri PS Products | Principal Product Engineer |
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220830/f9f436d3/attachment.htm>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220830/f9f436d3/attachment.obj>
