[postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Regina Obe
lr at pcorp.us
Tue Aug 30 16:56:12 PDT 2022
Oh you are running 3.2.2 and not 3.2.3. I know 3.2.3 has this file
postgis_raster--unpackaged--3.2.3.sql
which is what you are missing.
Can you install 3.2.3? Then once you install the binaries, run again and it should work.
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Marcelo Marques
Sent: Tuesday, August 30, 2022 7:39 PM
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Subject: Re: [postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Hello Regina,
I tried but the upgrade still failed, see below.
--create an empty file named "postgis--unpackaged.sql" in your share/extension folder of your PostgreSQL install.
--This file just has text
-- Nothing to do here
--C:\Program Files\PostgreSQL\11\share\extension folder
--And then try your upgrade again.
--SELECT postgis_extensions_upgrade();
NOTICE: Extension postgis_sfcgal is not available or not packagable for some reason
NOTICE: Packaging extension postgis_raster
ERROR: extension "postgis_raster" has no installation script nor update path for version "unpackaged"
CONTEXT: SQL statement "CREATE EXTENSION postgis_raster SCHEMA public VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
SQL state: 22023
--SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
"postgis" "3.2.2" "3.2.2" "PostGIS geometry and geography spatial types and functions"
--only the postgis extension is installed!!!
--CREATE EXTENSION postgis_raster;
ERROR: PostGIS Raster is already installed in schema 'public' CONTEXT: PL/pgSQL function inline_code_block line 10 at RAISE SQL state: P0001
--SELECT postgis_full_version();
"POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110"" GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not found"" LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)""
RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!] (raster procs from ""2.5.2 r17328"" need upgrade)"
Thanks for the assistance.
Marcelo
On Tue, Aug 30, 2022 at 3:56 PM Regina Obe <lr at pcorp.us <mailto:lr at pcorp.us> > wrote:
Marcelo,
Apologies, this file was left out in my packaging. I’ll create an updated package later this week to fix this issue and will also have a 3.3.0 which doesn’t have this issue.
I’ve updated ticket to reflect.
Copy the attached file (which is essentially an empty file) into your
Sorry for the omission,
Regina
From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org <mailto:postgis-users-bounces at lists.osgeo.org> ] On Behalf Of Marcelo Marques
Sent: Tuesday, August 30, 2022 6:08 PM
To: postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
Subject: [postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Hello,
I am trying to get a workaround for the problem below.
see more details in this link
https://trac.osgeo.org/postgis/ticket/5222#ticket
Have you encountered this issue before? If yes, do you know how to fix it ?
Thanks,
| Marcelo Marques | Esri PS Products | Principal Product Engineer |
postgis-users mailing list
https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220830/1951f13b/attachment.htm>
