[postgis-users] extension "postgis_raster" has no installation script nor update path for version "unpackaged"
Marcelo Marques
marcelosmbr at gmail.com
Wed Aug 31 11:03:15 PDT 2022
-- Yes, I have Postgis 3.2.2 for PostgreSQL 11 installed and it already
contain a file named "postgis--unpackaged--3.2.2.sql" under "C:\Program
Files\PostgreSQL\11\share\extension"
C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpackaged*.*
Directory of C:\Program Files\PostgreSQL\11\share\extension
03/11/2019 12:12 PM 1,475,393 postgis--unpackaged--2.5.2.sql
07/30/2022 12:49 AM 1,068,869 postgis--unpackaged--3.2.2.sql
08/30/2022 04:14 PM 21 postgis--unpackaged.sql
-- I compared the file C:\Program
Files\PostgreSQL\11\share\extension\postgis--unpackaged--3.2.2.sql on my
server
-- with the one from
https://winnie.postgis.net/download/windows/pg11/buildbot/extras/postgis--unpackaged--3.2.2.sql
-- and they are identical.
-- and still fails to upgrade.
-- SELECT postgis_extensions_upgrade();
NOTICE: Extension postgis_sfcgal is not available or not packagable for
some reason
NOTICE: Packaging extension postgis_raster
ERROR: extension "postgis_raster" has no installation script nor update
CONTEXT: SQL statement "CREATE EXTENSION postgis_raster SCHEMA public
VERSION unpackaged;ALTER EXTENSION postgis_raster UPDATE TO "3.2.2""
PL/pgSQL function postgis_extensions_upgrade() line 71 at EXECUTE
SQL state: 22023
-- I followed you suggestion and installed Postgis 3.2.3 for PostgreSQL 11
-- I checked and PostGIS 3.2.3 has the empty file "C:\Program
Files\PostgreSQL\11\share\extension\postgis--unpackaged.sql"
-- This file just has text "-- Nothing to do here"
C:\Program Files\PostgreSQL\11\share\extension>dir postgis--unpa*.*
08/19/2022 04:24 PM 1,465,258 postgis--unpackaged--3.2.3.sql
-- I was able to upgrade the postgis extension
-- and upgrade the raster extension and then
-- remove the raster extension and
-- if I want I can reinstall postgis_raster extension
-- SELECT postgis_full_version();
"POSTGIS=""3.2.3 3.2.3"" [EXTENSION] PGSQL=""110""
GEOS=""3.10.3-CAPI-1.16.1"" PROJ=""7.2.1""
GDAL=""GDAL 2.2.4, released 2018/03/19 GDAL_DATA not found""
LIBXML=""2.9.9"" LIBJSON=""0.12""
LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0 (Internal)"" (core procs from ""3.2.2
3.2.2"" need upgrade) <== !!! 3.2.2 NEED UPGRADE !!!
RASTER (raster lib from ""2.5.2 r17328"" need upgrade) [UNPACKAGED!]
(raster procs from ""2.5.2 r17328"" need upgrade)"
-- ALTER EXTENSION postgis UPDATE;
Query returned successfully in 599 msec.
NOTICE: version "3.2.3" of extension "postgis" is already installed
ALTER EXTENSION
Query returned successfully in 160 msec.
"Upgrade completed, run SELECT postgis_full_version(); for details"
NOTICE: Updating extension postgis from 3.2.2 to 3.2.3
some reason
WARNING: 'postgis.gdal_datapath' is already set and cannot be changed
until you reconnect
WARNING: 'postgis.gdal_enabled_drivers' is already set and cannot be
changed until you reconnect
WARNING: 'postgis.enable_outdb_rasters' is already set and cannot be
NOTICE: Extension postgis_topology is not available or not packagable for
some reason
NOTICE: Extension postgis_tiger_geocoder is not available or not
packagable for some reason
Successfully run. Total query runtime: 1 secs 884 msec.
1 rows affected.
GDAL=""GDAL 3.4.3, released 2022/04/22 GDAL_DATA not found""
LIBXML=""2.9.9"" LIBJSON=""0.12"" LIBPROTOBUF=""1.2.1"" WAGYU=""0.5.0
(Internal)"" RASTER"
-- SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
"postgis" "3.2.3" "3.2.3" "PostGIS geometry and geography spatial types and
functions"
-- CREATE EXTENSION postgis_raster;
ERROR: extension "postgis_raster" already exists
SQL state: 42710
-- NOTE: if postgis_raster already exists then pg_available_extensions
should have showed that, seems another bug to fix !!!
-- DROP EXTENSION postgis_raster;
DROP EXTENSION
Query returned successfully in 125 msec.
(Internal)"""
--NOTE: RASTER EXTENSION REMOVED !!!
-- Try to install postgis_raster extension
CREATE EXTENSION
Query returned successfully in 252 msec.
functions"
--NOTE: pg_available_extensions still does not show postgis_raster but in
pgAdmin when expand the "Extensions" I can see "postgis" and
"postgis_raster".
DROP EXTENSION
I appreciated your assistance.
Thanks,
Marcelo
On Tue, Aug 30, 2022 at 8:42 PM Regina Obe <lr at pcorp.us> wrote:
> I guess my attachment was too big.
> Here is a link to it if you need it,
> but if you are running a patched PostgreSQL 11, you’ll really need to be
> using the PostGIS 3.2.3 install which you can get from application
> stackbuilder or https://download.osgeo.org/postgis/windows/pg11/
> Hope that helps,
> Regina
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Tuesday, August 30, 2022 8:00 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Subject:* RE: [postgis-users] extension "postgis_raster" has no
> Attached is the one for 3.2.2
> But that is in my artifacts so should have already been installed by your
> setup. Do you have the attached file in your share/extension folder?
> *From:* Regina Obe [mailto:lr at pcorp.us <lr at pcorp.us>]
> *Sent:* Tuesday, August 30, 2022 7:56 PM
> Oh you are running 3.2.2 and not 3.2.3. I know 3.2.3 has this file
> postgis_raster--unpackaged--3.2.3.sql
> which is what you are missing.
> Can you install 3.2.3? Then once you install the binaries, run again and
> it should work.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
> <postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Marcelo Marques
> *Sent:* Tuesday, August 30, 2022 7:39 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] extension "postgis_raster" has no
> Hello Regina,
> I tried but the upgrade still failed, see below.
> --create an empty file named "postgis--unpackaged.sql" in your
> share/extension folder of your PostgreSQL install.
> --This file just has text
> --C:\Program Files\PostgreSQL\11\share\extension folder
> --And then try your upgrade again.
> --SELECT postgis_extensions_upgrade();
> some reason
> SQL state: 22023
> --SELECT * FROM pg_available_extensions WHERE name LIKE 'postgis';
> "postgis" "3.2.2" "3.2.2" "PostGIS geometry and geography spatial types
> and functions"
> --only the postgis extension is installed!!!
> --CREATE EXTENSION postgis_raster;
> ERROR: PostGIS Raster is already installed in schema 'public' CONTEXT:
> PL/pgSQL function inline_code_block line 10 at RAISE SQL state: P0001
> --SELECT postgis_full_version();
> "POSTGIS=""3.2.2 3.2.2"" [EXTENSION] PGSQL=""110""
> (Internal)""
> Thanks for the assistance.
> Marcelo
> On Tue, Aug 30, 2022 at 3:56 PM Regina Obe <lr at pcorp.us> wrote:
> Marcelo,
> Apologies, this file was left out in my packaging. I’ll create an updated
> package later this week to fix this issue and will also have a 3.3.0 which
> doesn’t have this issue.
> I’ve updated ticket to reflect.
> Copy the attached file (which is essentially an empty file) into your
> Sorry for the omission,
> Regina
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> *Sent:* Tuesday, August 30, 2022 6:08 PM
> *To:* postgis-users at lists.osgeo.org
> *Subject:* [postgis-users] extension "postgis_raster" has no installation
> Hello,
> I am trying to get a workaround for the problem below.
> see more details in this link
> https://trac.osgeo.org/postgis/ticket/5222#ticket
> Have you encountered this issue before? If yes, do you know how to fix it ?
> Thanks,
> | *Marcelo Marques *| Esri PS Products | Principal Product Engineer |
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220831/6aa50956/attachment.htm>
