[postgis-users] Prorate values along a line feature based on length.
Simon Norris snorris at hillcrestgeo.ca
Wed Jan 5 09:17:41 PST 2022
Bobb,
It sounds like you want to add measures from the endpoints:
https://postgis.net/docs/ST_AddMeasure.html <https://postgis.net/docs/ST_AddMeasure.html>
Then grab the interpolated elevations with something like this:
SELECT ST_Z(ST_PointN(geom, generate_series(1, ST_NPoints(geom) - 1))) AS elevation
Simon
> On Jan 5, 2022, at 9:03 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
> All,
> Ok, this is sort of a weird one (to me).
> I have a feature dataset of MutliLineStrings, all with no Z value, but with a Elevation attribute on each end.   I need to prorate the elevation for each vertex along the line based on the distance for either/or each of the ends.
> I was planning on attaching this from the client side originally, but though I would ask here if anyone has tried a SQL approach to extracting/creating.
> Maybe recreate the feature with the attiributes on the fly?  Then extract the vertex info.  The intent is to import into a CAD application and build a 3D CAD model.
> Anyway, any thoughts?
> Bobb
> Get me in Teams <https://teams.microsoft.com/l/chat/0/0?users=bob.basques@ci.stpaul.mn.us>
> PW19-S295-C024
> postgis-users mailing list
> postgis-users at lists.osgeo.org <mailto:postgis-users at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/postgis-users <https://lists.osgeo.org/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220105/0d5a221e/attachment.html>
