[postgis-users] How best to create and use associative array type in Postgres?
Shaozhong SHI
shishaozhong at gmail.com
Sat Jan 8 06:15:59 PST 2022
Hi, Regina,
It does look like that jsonb can work as a dictionary, and there are a
versatile collection of operators and methods.
To push in a new key value pair, modifying the value given a key, pop out
the one which has been dealt with is interesting.
Alternatively, we can iterate over the dictionary by using loop.
Regards,
David
On Sat, 8 Jan 2022 at 04:20, Regina Obe <lr at pcorp.us> wrote:
> Oh forgot one more very useful operator, the subtraction operator.
> Removes a key/value from the list:
> SELECT '{"color": "blue", "height_m": 10}'::jsonb - 'color'
> Returns:
> {"height_m": 10}
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Friday, January 7, 2022 11:18 PM
> *To:* 'PostGIS Users Discussion' <postgis-users at lists.osgeo.org>
> *Subject:* RE: [postgis-users] How best to create and use associative
> David,
> Not sure what you are asking? There are many functions for jsonb and even
> more the newer your PostgreSQL is.
> Take a look at -
> https://www.postgresql.org/docs/current/functions-json.html
> You can pull arrays by index but not really key/values by index (because
> jsonb reorders keys/values for efficiency). So order shouldn’t matter in
> jsonb as the same level keys are unique.
> The trick of using the concatenation operator (||) to update keys values
> works, because the last entry for a key wins, and any key not in the list
> gets replaced by the last one. So I guess your popping idea
> Take for example:
> SELECT '{"color": "blue", "height_m": 10}'::jsonb || '{"color":
> "red"}'::jsonb || '{"width_m": 5}';
> Returns:
> {"color": "red", "width_m": 5, "height_m": 10}
> Note how the entry width_m was added, but not the order you specified it,
> and that the color was changed from blue to red.
> Now if you wanted to get a set of all the key value pairs, you’d use
> jsonb_each_text (to get value as text) or jsonb_each to get the value as a
> jsonb.
> Here is an example:
> WITH a AS (SELECT '{"color": "blue", "height_m": 10}'::jsonb || '{"color":
> "red"}'::jsonb || '{"width_m": 5}' AS data)
> SELECT kv.*
> FROM a, jsonb_each_text(a.data) AS kv;
> Returns:
> color red
> width_m 5
> height_m 10
> Now lets do this with PostGIS J
> WITH a AS (
> SELECT ST_AsGeoJSON(ST_MakeLine( ARRAY[ST_Point(1,2), ST_Point(3,4),
> ST_Point(-9,1)]))::jsonb AS data
> SELECT kv.key, kv.value, kv.value->2->>0 AS last_x
> FROM a, jsonb_each(a.data) AS kv;
> key | value | last_x
> type | "LineString" |
> coordinates | [[1, 2], [3, 4], [-9, 1]] | -9
> (2 rows)
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
> <postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Shaozhong SHI
> *Sent:* Friday, January 7, 2022 9:25 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* Re: [postgis-users] How best to create and use associative
> Hi, Regina,
> That is interesting!
> How to add new entries to the dictionary. E.g., weight: 40?
> Can the dictionary to serve as a collection of paired key, value set, so
> that we can accumulate data to be processed?
> Then, we can deal with the first, then 2nd and so on in turn?
> Or, we can do things like pip and pop? Namely, when we have dealt with
> the first key, value pair, it will be out the dictionary, so that we can be
> sure that we are dealing with each key, value pair in turn?
> Alternatively, can we fetch each key, value pair by its index or position?
> Regards,
> David
> On Fri, 7 Jan 2022 at 21:19, Regina Obe <lr at pcorp.us> wrote:
> Use JSONB datatype.
> CREATE TABLE test(id integer, data jsonb);
> TRUNCATE tABLE test;
> INSERT INTO test(id, data)
> VALUES (1, '{"color": "red", "height_m": 10}');
> -- PG14 or higher – you can used subscript feature
> UPDATE test SET data['color'] = to_jsonb('blue'::text),
> data['height_m'] = to_jsonb(10), data['width_m'] = to_jsonb(2)
> WHERE id = 1;
> -- PG14 or lower
> UPDATE test SET data = jsonb_set(data, ARRAY['color'],
> to_jsonb('blue'::text), true)
> WHERE id = 1;
> -- PG14 or lower to set multiple
> UPDATE test SET data = data || '{"color": "blue", "height_m": 10}'::jsonb;
> -- To read (all versions)
> SELECT data->>'color' AS color, (data->>'height_m')::integer As height_m
> FROM test;
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> *Sent:* Wednesday, January 5, 2022 1:30 PM
> *Subject:* [postgis-users] How best to create and use associative array
> type in Postgres?
> In Oracle, one can create and use associative array. For instance,
> TYPE FID_MEASURE IS TABLE OF NUMBER INDEX BY VARCHAR2(38);
> NODES_WAITING FID_SET;
> Or, what is the best/most efficient equivalent in Postgres?
> Regards,
> David
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220108/b160a635/attachment.html>
