[postgis-users] hard upgrade from 1.5
Nathan Wagner
nw at hydaspes.if.org
Mon Jan 10 10:01:14 PST 2022
I am working on an upgrade from postgis 1.5 on postgresql 9.0 to postgis
2.5 on postgresql 11.
The docs say that a hard upgrade is needed. Is that still true if we're
migrating the data from one database to another? Our migration strategy
is to do a copy out of the table data (as in a \copy psql command, or
equivalent) from the source and a copy in at the target. An examination
of the results seem to indicate that the data is copied correctly.
I had been under the impression that the binary format had changed, but
I am unable to find an example of this.
So, if you're not upgrading in place, but doing a copy, is a "hard" type
upgrade needed? My earlier strategy had been to select the data out of
the database wrapping the geometry columns in st_asewkt() on the way out
and similarly on the way in. This doesn't seem like it's needed and I
can just use the binary representation directly.
I had thought that postgis_restore.pl would have done some sort of
wrapper, but I think it just adjusts the manifest list of a pg_restore
-l, which we don't need in our case since we have the new version of
postgis already installed on the new database.
I can't find any mention of a change in the binary format in the git
logs, but if there weren't a binary format change, I would have thought
that a simple 'from unpackaged' script to convert to an extension would
have been sufficient and could have been done in place without needing
anything special.
So, why exactly is a hard upgrade needed from 1.5 to 2.5?
Can I do a copy to file from the 1.5 and then copy from that file to 2.5
and expect it to work? If not, why not, what sort of errors should I
expect? A specific example of something that doesn't work would be
ideal, since then I could then write a failing test.
nw
