[postgis-users] PostGIS problem after updating from 3.1.4 to 3.2.0
Calle Hedberg
calle.hedberg at gmail.com
Tue Jan 11 03:23:43 PST 2022
Dear Regina,
Just running SELECT postgis_extensions_upgrade(); did not work.
I reinstalled PostGIS 3.1.4, and verified that it was functional.
I then reinstalled 3.2.0 on top of that, this time successfully (not sure
why I had to remove 3.1.4 the first time, but...), and then ran
SELECT postgis_full_version();
on all databases, and that worked OK.
So I will do the same for PG14 and ditto on my other two systems. It's a
bit time consuming since I have 150-200 databases in total, so if you can
fix that bug so that there is no need to run the extension upgrade command
on every db it would be great.. I've got one pg10 and one pg12 installation
too to cater for some backward compatibility and to provide an upgrade path
for old databases, but I'm leaving those on 3.0 / 3.1
Thanks again for the rapid response and the clear instructions.
Best regards
Calle
On Tue, 11 Jan 2022 at 04:21, Regina Obe <lr at pcorp.us> wrote:
> Side note I’ve ticketed the issue here:
> https://trac.osgeo.org/postgis/ticket/5045
> and will update once I release a new package
> *From:* Regina Obe [mailto:lr at pcorp.us]
> *Sent:* Monday, January 10, 2022 10:21 PM
> *To:* 'calle.hedberg at gmail.com' <calle.hedberg at gmail.com>; 'PostGIS Users
> Discussion' <postgis-users at lists.osgeo.org>
> *Subject:* RE: [postgis-users] PostGIS problem after updating from 3.1.4
> to 3.2.0
> Hmm okay it looks like I forgot to take off the minor version in my
> release so all the libs
> Have -3.2 on them instead of -3. I guess I didn’t notice cause I usually
> just install the new version over the old.
> And then run
> Though I’m still surprised it’s giving an error as I thought we fixed that
> issue a long time ago to handle a case where the lib file has been removed.
> So that seems like a reemerging old bug.
> That said , while I’m making a new package. Can you do the following:
> First try if:
> -- works without doing anything else
> If the above still gives you an error, do the following
> Reinstall PostGIS 3.1.4
> Reinstall PostGIS 3.2.0
> Then run
> In each of your databases.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org
> <postgis-users-bounces at lists.osgeo.org>] *On Behalf Of *Calle Hedberg
> *Sent:* Monday, January 10, 2022 9:53 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> *Subject:* [postgis-users] PostGIS problem after updating from 3.1.4 to
> 3.2.0
> Hi,
> I just updated postgresql 13 and pg 14 (running on the D-drive under
> Windows 10 64 bits) from 3.14 to 3.2.0. (in order to install 3.2, I had to
> first remove 3.1.4 - then I installed 3.2.0 using Stackbuilder run as
> administrator).
> When running "create extension postgis;" in pgAdmin, I get as expected a
> message that extension postgis already exists. But it actually does not
> exist/start up - if I run e.g. "select postgis_full_version();", it returns
> ERROR: could not access file "$libdir/postgis-3": No such file or
> directory CONTEXT: SQL statement "SELECT public.postgis_lib_version()"
> PL/pgSQL function postgis_full_version() line 26 at SQL statement SQL
> state: 58P01
> If I run "ALTER EXTENSION postgis UPDATE TO "3.2.0"; " I get a similar
> message:
> directory CONTEXT: PL/pgSQL function
> _postgis_drop_function_if_needed(text,text) line 6 at FOR over SELECT rows
> SQL state: 58P01
> I can force the issue by dropping the postgis extension and recreate it,
> but then I have to use drop extension postgis cascade and that command will
> wipe out the geometry fields in the database (dropping ext postgis on the
> template postgres db work fine, but that db does not have any geometry
> fields).
> I have tried to re-start pg, reboot the machine, and googling the issue,
> to no avail.
> I can see that postgis 3.2.0 has been installed:
> D:\Program Files\PostgreSQL\13\share\contrib\postgis-3.2
> I see the error message states it cannot find postgis-3 - but there IS no
> such file or directory, as you can see the directory is actually called
> postgis-3.2 . But I don't know if that's a bug or what...
> Any suggestions - or will I have to dump all my databases and then
> re-install pg 13 and pg14 afresh?
> Best regards
> Calle
*Carl-Anders (Calle) Hedberg*
HISP
Researcher & Technical Specialist
Health Information Systems Programme – South Africa
Cell: +47 41461011 (Norway)
Iridium SatPhone: +8816-315-19119 (usually OFF)
E-mail1: calle at hisp.org
E-mail2: calle.hedberg at gmail.com
Skype: calle_hedberg
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220111/3222bf6b/attachment.html>
