[postgis-users] PostGIS 3.3.0alpha1 released
Anthony DeBarros
anthonymdebarros at gmail.com
Sat Jun 4 07:37:32 PDT 2022
On Fri, Jun 3, 2022 at 11:59 PM Regina Obe <lr at pcorp.us> wrote:
> Anthony,
> Thanks again for pointing out that EDB does have windows binaries and
> installers for PG15beta1.
> I’ve started the build process for PG15 beta. You’ll find it here:
> https://winnie.postgis.net/download/windows/pg15/buildbot/
Thanks, Regina! That works!
SELECT version();
"PostgreSQL 15beta1, compiled by Visual C++ build 1914, 64-bit"
SELECT postgis_version();
"3.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
> *From:* Anthony DeBarros [mailto:anthonymdebarros at gmail.com]
> *Sent:* Friday, June 3, 2022 9:11 PM
> *To:* Regina Obe <lr at pcorp.us>
> *Subject:* Re: [postgis-users] PostGIS 3.3.0alpha1 released
> Hi, Regina,
> I was able to find the Windows installers for the PG15 beta from EDB here:
> https://www.enterprisedb.com/products-services-training/pgdevdownload
> That's linked from this page:
> https://www.postgresql.org/download/snapshots/
> Best,
> Anthony
> On Fri, Jun 3, 2022 at 3:01 PM Regina Obe <lr at pcorp.us> wrote:
> I missed the last part of your message. I didn’t think the PG15beta for
> windows was out.
> Where are you getting that from or did you compile it yourself?
> Not much trouble for me to start building for PG15, I do so locally anyway
> to make sure we have no breaking changes.
> But as mentioned each version of PostgreSQL requires its own compilation.
> Something lots of people complain about.
> *From:* postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] *On
> Behalf Of *Anthony DeBarros
> *Sent:* Monday, May 30, 2022 3:39 PM
> *To:* PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> On Mon, May 30, 2022 at 12:45 PM Regina Obe <lr at pcorp.us> wrote:
> The PG14 windows binaries are here -
> https://winnie.postgis.net/download/windows/pg14/buildbot/
> You will see a 3.3.0alpha1 -
> https://winnie.postgis.net/download/windows/pg14/buildbot/postgis-pg14-binaries-3.3.0alpha1w64gcc81.zip
> One more question, Regina ...
> Are those binaries supposed to also work with the PG15 beta or no? I've
> tried but am getting a message that they're for PG14.
> Thanks again!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220604/c720d9e1/attachment.htm>
