[postgis-users] A function to find errors in groups in a table
Vera Green
vera.green.ca at gmail.com
Thu Jun 9 16:53:07 PDT 2022
Use a window function to find where outflow =< inflow with the window on
the nodeid.
On Thu., Jun. 9, 2022, 5:28 a.m. Shaozhong SHI, <shishaozhong at gmail.com>
wrote:
> There is a table full of grouped values like the following
> nodeid link_type primary
> 11 outflowlink 1
> 11 inflowlink 1
> 11 outflowlink 2
> Primary of 1 indicates a primary water course. Primary of 2 indicates a
> secondary water course.
> Obviously, one of the out flow links is an error, as its primacy value is
> 2. It is wrong that water flows from a primary water course into a
> How can a function can be designed to find and report such errors?
> Regards,
> David
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220609/e59be66e/attachment.htm>
