[postgis-users] Fwd: problem with points in polygon edge
Gustavo Martinez
gmpuljak at yahoo.com.ar
Thu Mar 17 04:54:22 PDT 2022
-------- Mensaje reenviado --------
Asunto: Re: [postgis-users] problem with points in polygon edge
Fecha: Wed, 16 Mar 2022 15:21:31 -0300
De: Gustavo Martinez <gmpuljak at yahoo.com.ar>
A: Greg Troxel <gdt at lexort.com>
Hi Greg,
I can't share the database. Attached are 2 shapefiles with the data of
the following example (consider that the queries run on the server):
- select b.grado, b.cuarto, count(idvms) from monitoreo.vms_2021 a,
datos.cuadricula_05 b where a.idprts='20215019326' and
st_within(a.geom,b.geom) group by 1,2;
Gives:
grado cuarto count
3857 NE 13
3857 NO 49
3857 SO 6
3858 SE 13
3958 NE 16
3958 SO 16
4058 NO 15
4059 NE 3
4059 SE 19
4159 NE 11
4159 NO 6
4159 SO 18
4259 NO 18
4259 SO 10
4260 SE 6
4360 NE 17
4360 SE 14
4459 NO 453
4460 NE 307
st_intersects(a.geom,b.geom) group by 1,2;
Gives:
grado cuarto count
3857 NE 13
3857 NO 49
3857 SO 6
3858 SE 13
3958 NE 16
3958 SO 16
4058 NO 15
4059 NE 3
4059 SE 19
4159 NE 11
4159 NO 6
4159 SO 18
4259 NO 18
4259 SO 10
4260 SE 6
4360 NE 17
4360 SE 14
4459 NO 461
4460 NE 315
monitoreo.dentro(a.geom,b.geom) group by 1,2;
Gives:
grado cuarto count
3958 SO 16
4259 NO 18
4059 NE 3
4159 NO 6
4460 NE 315
3857 NE 13
4159 SO 18
3958 NE 16
3857 SO 6
3857 NO 49
4360 NE 17
4260 SE 6
4259 SO 10
4459 NO 453
4058 NO 15
3858 SE 13
4360 SE 14
4059 SE 19
4159 NE 11
- select count(idvms) from monitoreo.vms_2021 where idprts='20215019326'
Gives:
count
1018
You can see that st_intersects adds points and st_within gives a lower
count that the real one.
El 16/3/22 a las 14:30, Greg Troxel escribió:
> You still haven't explained what you are trying to do, and haven't
> posted your queries. That's ok, but I have not further useful
> suggestions for you.
*Gustavo Martínez Puljak*
*cel: +549 11 64089000
Linkedin:www.linkedin.com/in/gustavomartinezpuljak
<https://www.linkedin.com/in/gustavomartinezpuljak>
*/Que la tierra se vaya haciendo camino ante tus pasos,//
//que el viento sople siempre a tus espaldas,//
//que el sol brille cálido sobre tu cara,//
//que la lluvia caiga suavemente sobre tus campos y,//
//hasta tanto volvamos a encontrarnos,//
//que Dios te lleve en la palma de su mano./
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220317/a6155bff/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220317/a6155bff/attachment.zip>
