[postgis-users] Enabling output GDAL Driver
Saulteau Don
sault.don at gmail.com
Sat Mar 26 09:20:23 PDT 2022
Maybe see if the correct environment variable also need to be set?
POSTGIS_GDAL_ENABLED_DRIVERS
Specifies a list of GDAL drivers to enable (rather than skip) By default
all drivers are disabled. Example value: “GTiff PNG JPEG”
POSTGIS_ENABLE_OUTDB_RASTERS
Enables read support for out-db raster bands if set to 1. By default out-db
raster bands reading is disabled.
That's taken from the security notes at
https://postgis.net/2014/05/19/postgis-2.0.6_and_2.1.3/
saultdon
On Sat., Mar. 26, 2022, 08:02 David Haynes, <haynesd2 at gmail.com> wrote:
> Hello List,
> Running into an error running a 3rd party application GeoServer (2.16) to
> visualize rasters stored in PostgreSQL. It seems my PostgreSQL DB has not
> enabled the output GDAL driver.
> ERROR: rt_raster_to_gdal: Could not load the output GDAL driver
> 2022-03-26 10:32:24,110 ERROR [jdbc.custom] - ERROR: rt_raster_to_gdal:
> Where: PL/pgSQL function st_astiff(raster,text[],integer) line 24 at
> RETURN
> org.postgresql.util.PSQLException: ERROR: rt_raster_to_gdal: Could not
> Overstack suggested this, but it hasn't worked. Do I have to recompile?
> SET postgis.gdal_enabled_drivers = 'ENABLE_ALL';
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220326/9be01e04/attachment.html>
