[postgis-users] Cut extent box2d into small regular boxes, and iterate through each box of features
Shaozhong SHI
shishaozhong at gmail.com
Mon Mar 28 04:14:53 PDT 2022
Hi, Lars,
Thanks for suggestions.
Your execute parallel is very interesting. Are there explanations or a
documentation or a guide available?
Regards,
David
On Mon, 28 Mar 2022 at 11:09, Lars Aksel Opsahl <Lars.Opsahl at nibio.no>
wrote:
> >From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of
> Shaozhong SHI <shishaozhong at gmail.com>Sent: Monday, March 28, 2022 11:42
> AMTo: PostGIS Users Discussion <postgis-users at lists.osgeo.org>Subject:
> Re: [postgis-users] Cut extent box2d into small regular boxes, and iterate
> >Hi, Lars,
> >Would the following alternative work?
> >In PostGIS, one can group by geometry. Based on this information, can
> grid be generated? so that grid with 0 features can be skipped.
> Hi
> In our cases this would not solve our problems, because grid cells with
> zero content does not cause any big performance issue problems, but we do
> not need them so it's nice to get reed of them.
> But I think it's easier to have a complete grids coverage and instead vary
> cell size based on content. If you have a set of 10 mill polygons and and
> you make a grid so you can process them in parallel what's important is
> that each job has about the same needs related to memory and CPU, and this
> can be done by setting for instance a max a value for number of features pr
> cell. (You can here also count number points in each polygon but that takes
> more time and you can not base the grid cell creation on indexes)
> Lars
> postgis-users mailing list
> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220328/3f024def/attachment.html>
