[postgis-users] Cut extent box2d into small regular boxes, and iterate through each box of features
Simon SPDBA Greener simon at spdba.com.au
Tue Mar 29 02:16:34 PDT 2022
I think the following procedure and function will do what you want.
There is some documentation in the driving procedure.
-- Example
CALL spdba.QuadTree(
   p_SearchOwner  := 'data',
   p_SearchTable  := 'valves',
   p_SearchColumn := 'geom',
   p_LL           :=
ST_GeomFromEWKT('SRID=28356;POINT(515698.10890000034 6960213.1757)'),
   p_UR           :=
ST_GeomFromEWKT('SRID=28356;POINT(519045.1911000004  6965208.943 )'),
   p_TargetOwner  := 'data',
   p_TargetTable  := 'valves_q',
   p_TargetColumn := 'geom',
   p_MaxQuadLevel := 8,
   p_MaxCount     := 100
regards
Simon
DROP procedure if exists
spdba.QuadTree(Varchar(250),VARCHAR(250),VARCHAR(250),geometry,geometry,Varchar(250),varchar(250),VARCHAR(250),integer,integer);
Create or Replace Procedure spdba.QuadTree(
   p_SearchOwner  IN Varchar(250),
   p_SearchTable  IN VARCHAR(250),
   p_SearchColumn IN VARCHAR(250),
   p_LL           IN geometry,
   p_UR           IN geometry,
   p_TargetOwner  IN Varchar(250),
   p_TargetTable  IN varchar(250),
   p_TargetColumn IN VARCHAR(250),
   p_MaxQuadLevel IN integer,
   p_MaxCount     IN integer
LANGUAGE 'plpgsql'
SECURITY DEFINER
As
/****f* TESSELATION/ST_QuadTree
  *  NAME
  *   ST_QuadTree - Tesselates a two-dimensional space using a simple
recursive quad tree grid.
  *  SYNOPSIS
  *    Procedure spdba.QuadTree(
  *      p_SearchOwner  IN Varchar(250),
  *      p_SearchTable  IN VARCHAR(250),
  *      p_SearchColumn IN VARCHAR(250),
  *      p_LL           IN geometry,
  *      p_UR           IN geometry,
  *      p_TargetOwner  IN Varchar(250),
  *      p_TargetTable  IN varchar(250),
  *      p_TargetColumn IN VARCHAR(250),
  *      p_MaxQuadLevel IN integer,
  *      p_MaxCount     IN integer
  *  DESCRIPTION
  *    Recursively tesselates the two-dimensional space defined by
p_SearchTable using a
  *    quad tree algorithm based on a set of criteria:
  *      1. Depth of the Quad Tree;
  *      2. Max number of features per quad
  *         (If number in a quad is > max number, quad is divided into
four and each quad feature count is recomputed)
  *    The ouput polygons representing the quads that contain the data
  *    are written to the p_TagetTable with some specific fields
  *  PARAMETERS
  *    p_SearchOwner  - Varchar(250) - Schema owner of p_SearchTable table
  *    p_SearchTable  - VARCHAR(250) - Name of table in p_SchemaOwner
that is to be quadded
  *    p_SearchColumn - VARCHAR(250) - Geometry column in p_SearchTable
containing spatial data to be quadded.
  *    p_LL           - geometry     - Lower Left corner of extent of
data in p_SearchColumn to be quadded (normally LL of extent of all data
in p_searchColumn)
  *    p_UR           - geometry     - Upper Right corner of extent of
data in p_SearchColumn to be quadded (normally UR of extent of all data
in p_searchColumn)
  *    p_TargetOwner  - Varchar(250) - Schema owner of p_TargetTable
  *    p_TargetTable  - varchar(250) - Name of table that will be
created and will hold the quad tree rectangles.
  *    p_TargetColumn - VARCHAR(250) - Name of geometry column in
p_TargetTable that will hold resultant quad rectangles.
  *    p_MaxQuadLevel - integer      - Maximum depth to recurse.
  *    p_MaxCount     - integer      - Max number of features per quad
tree rectangle.
  *  EXAMPLE
  *    CALL spdba.QuadTree(
  *            p_SearchOwner  := 'data',
  *            p_SearchTable  := 'valves',
  *            p_SearchColumn := 'geom',
  *            p_LL           :=
  *            p_UR           :=
  *            p_TargetOwner  := 'data',
  *            p_TargetTable  := 'valves_q',
  *            p_TargetColumn := 'geom',
  *            p_MaxQuadLevel := 8,
  *            p_MaxCount     := 200
  *  NOTE
  *    Ignores Z and only supports geometry objects not geography
(separate procedure)
  *  HISTORY
  *    Simon Greener - March 2022 - Converted from Oracle PL/SQL
  *  COPYRIGHT
  *    Licensed under a Creative Commons Attribution-Share Alike 2.5
Australia License. (http://creativecommons.org/licenses/by-sa/2.5/au/)
$OUTER$
DECLARE
   v_sql        text;
   v_insert_sql text;
   v_select_sql text;
   v_result     integer;
   v_searchOwnerTable text := case when p_searchOwner is null then ''
else p_searchOwner || '.' end || p_SearchTable;
   v_TargetOwnerTable text := case when p_TargetOwner is null then ''
else p_TargetOwner || '.' end || p_TargetTable;
BEGIN
   /***** Inner subroutine*/
   Drop Function IF EXISTS spdba.QuadTree(integer, geometry, geometry,
integer, integer, integer, text, text);
   Create Function spdba.QuadTree(p_QuadId       IN INTEGER,
                                  p_LL           IN geometry,
                                  p_UR           IN geometry,
                                  p_QuadLevel    IN INTEGER,
                                  p_maxQuadLevel in integer,
                                  p_MaxCount     in integer,
                                  p_insert_sql   in text,
                                  p_search_sql   in text)
   RETURNS INTEGER
   LANGUAGE 'plpgsql'
   AS
   $INNER$
   DECLARE
     v_count     INTEGER;
     v_temp      double precision;
     v_QuadLevel INTEGER;
     v_QuadID    INTEGER;
     v_LL        geometry;
     v_UR        geometry;
   BEGIN
     v_QuadId    := p_QuadId;
     v_QuadLevel := p_QuadLevel;
     v_LL        := p_LL;
     v_UR        := p_UR;
     -- Performance optimisation
     -- When at level 0 don't execute a search but start tesselating
     If ( v_QuadLevel <> 0 ) Then
       EXECUTE p_search_sql
               INTO v_count
               USING
ST_X(p_LL)::float,ST_Y(p_LL)::float,ST_X(p_UR)::float,ST_Y(p_UR)::float,ST_Srid(p_LL)::integer;
       IF ( v_count = 0 ) THEN
         RETURN v_QuadId;
       END IF;
       IF ( v_count <= p_MaxCount ) THEN
         EXECUTE p_insert_sql
           USING p_QuadId,
                 v_QuadLevel,
                 v_count,
                 ST_X(v_LL), ST_Y(v_LL),
                 ST_X(v_UR), ST_Y(v_UR),
ST_MakeEnvelope(ST_X(v_LL)::float,ST_Y(v_LL)::float,ST_X(v_UR)::float,ST_Y(v_UR)::float,ST_Srid(p_LL)::integer);
         RETURN v_QuadId + 1;
       END IF;
     End If;
     v_QuadLevel := p_QuadLevel + 1;
     IF ( v_QuadLevel > p_MaxQuadLevel ) THEN
       RETURN v_QuadId;
     END IF;
     -- Still need to tessellate the space!
     -- initialize tmp node with corner data
     -- +---+---R
     -- | x |   |
     -- L---+---+
     v_UR       := ST_SetSrid(
                      ST_MakePoint(ST_X(v_LL) + ( ST_X(v_UR) -
ST_X(v_LL) ) / 2.0,
                      ST_Y(v_LL) + ( ST_Y(v_UR) - ST_Y(v_LL) ) / 2.0),
                      ST_SRID(v_LL)
     v_QuadId := spdba.QuadTree(v_QuadId,v_LL,v_UR,v_QuadLevel,
p_MaxQuadLevel,p_MaxCount,p_insert_sql,p_search_sql);
     -- | x |   |
     -- +---R---+
     -- | 1 |   |
     -- L---+---+
     v_temp := ( ST_Y(v_UR) - ST_Y(v_LL) );
     v_LL   :=
ST_SetSrid(ST_MakePoint(ST_X(v_LL),ST_Y(v_UR)),ST_Srid(v_UR));
     v_UR   := ST_SetSrid(ST_MakePoint(ST_X(v_UR),ST_Y(v_LL) +
v_temp),ST_Srid(v_LL));
     -- +---R---+
     -- | 2 |   |
     -- L---+---+
     -- |   | x |
     v_temp := ST_X(v_UR) - ST_X(v_LL);
     v_LL   := ST_SetSrid(ST_MakePoint(ST_X(v_UR),
ST_Y(v_LL)),ST_SRID(v_LL));
     v_UR   := ST_SetSrid(ST_MakePoint(ST_X(v_LL) +
v_temp,ST_Y(v_UR)),ST_SRID(v_LL));
     v_temp := ST_Y(v_UR) - ST_Y(v_LL);
     v_UR   := ST_SetSRID(ST_MakePoint(ST_X(v_UR),ST_Y(v_LL)),
ST_Srid(v_LL));
     v_LL   :=
ST_SetSRID(ST_MakePoint(ST_X(v_LL),ST_Y(v_UR)-v_temp),ST_Srid(v_LL));
     v_QuadId :=
spdba.QuadTree(v_QuadId,v_LL,v_UR,v_QuadLevel,p_MaxQuadLevel,p_MaxCount,p_insert_sql,p_search_sql);
     -- |   | x |
     -- +---+---U
     -- |   | 3 |
     -- +---L---+
     v_LL   := ST_SetSrid(ST_MakePoint(ST_X(v_LL),ST_Y(v_UR)),
ST_Srid(v_UR));
     v_UR   :=
ST_SetSrid(ST_MakePoint(ST_X(v_UR),ST_Y(v_LL)+v_temp),ST_Srid(v_ll));
     RETURN spdba.QuadTree(v_QuadId,v_LL,v_UR,v_QuadLevel,
   END;
   $INNER$;
   /***** End Inner subroutine*/
   IF ( p_LL is null or p_UR is null ) THEN
     RAISE EXCEPTION 'Starting LL and UR must not be null';
   END IF;
   v_insert_sql := 'INSERT INTO ' || v_TargetOwnerTable ||
                   ' (quad_id,quad_level,feature_count,xlo,ylo,xhi,yhi,'
|| p_TargetColumn || ') ' ||
                   ' VALUES ($1,$2,$3,$4,$5,$6,$7,$8)';
   v_select_sql := 'SELECT count(*)' ||
                   '  FROM '|| v_SearchOwnerTable || ' as a ' ||
                   ' WHERE ST_Intersects(a.' || p_SearchColumn ||
',ST_MakeEnvelope($1, $2, $3, $4, $5))';
   -- Drop target table.
   EXECUTE 'DROP TABLE IF EXISTS ' || v_TargetOwnerTable;
   -- CreateTargetTable
   v_sql := 'CREATE TABLE ' || v_TargetOwnerTable || '(
       quad_id       bigint NOT NULL,
       quad_level    integer,
       feature_Count integer,
       xlo           float,
       ylo           float,
       xhi           float,
       yhi           float,
       '|| p_TargetColumn || ' geometry)';
   EXECUTE v_sql;
   v_result := spdba.QuadTree( 0, p_LL, p_UR, 0, p_MaxQuadLevel,
p_MaxCount, v_insert_sql, v_select_sql );
   return;
END;
$OUTER$;
