[postgis-users] Is there a better way for Finding Gaps/Sliver Holes?
Shaozhong SHI shishaozhong at gmail.com
Mon May 2 08:18:06 PDT 2022
That certainly looks very interesting.  I will look into it.
What are the key concept and solutions?
Regards,
David
On Monday, 2 May 2022, Lars Aksel Opsahl <Lars.Opsahl at nibio.no> wrote:
> >From: postgis-users <postgis-users-bounces at lists.osgeo.org> on behalf of
> Shaozhong SHI <shishaozhong at gmail.com>
> >Sent: Monday, May 2, 2022 12:22 PM
> >To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
> >Subject: [postgis-users] Is there a better way for Finding Gaps/Sliver
> Holes?
> >This solution does not appear to be well explained.
> >Find Topology Error With PostGIS (khairu-aqsara.net)
> >Has anyone tested it?
> >Regards,
> >David
> Hi
> At https://github.com/larsop/find-overlap-and-gap
> we have code that checks for overlaps and gaps on simple feature polygons
> and creates a spatial tables with the results. We have used this code on
> tables  with millions  of rows.
> And yes we see gaps/overlap as polygons, lines and points .
> Lars
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220502/be9ad9fe/attachment.htm>
