[postgis-users] Is there a better way for Finding Gaps/Sliver Holes?
Shaozhong SHI shishaozhong at gmail.com
Mon May 2 13:48:59 PDT 2022
Sorry, I have not got any example dataset.
If some one can create a schematic/mock-up data set, we can test our way
forward.
I am looking into the fundamentals of data testing and quality assurance
techniques by using PostGIS.
Regards,
David
On Mon, 2 May 2022 at 19:57, Martin Davis <mtnclimb at gmail.com> wrote:
> Yes, that technique only applies to polygonal coverages.
> Your use case is not clear to me.  An example dataset might make that more
> clear.
> On Mon, May 2, 2022 at 11:40 AM Shaozhong SHI <shishaozhong at gmail.com>
> wrote:
>> On Mon, 2 May 2022 at 19:05, Martin Davis <mtnclimb at gmail.com> wrote:
>>> That blog post does provide useful queries for finding polygon overlaps
>>> and gaps.
>>> Overlaps are found via testing if polygon interiors intersect, using the
>>> DE-9IM relate mask 2********.
>>> Gaps are found by identifying holes in the union of the set of
>>> polygons.  One issue with this is that computing the union of large
>>> datasets can be slow.  Lars' solution provides some ideas for dealing with
>>> this.
>>> I think that matters are rather more complex than this.
>> For instance, I found 2 lines meet with each other at both ends.  In this
>> case, 2 intersections are both a point.  One will find two lines form an
>> enclosed area.
>> When 2 lines intersect or meet/touch more than 2 times, intersection will
>> return more than 2 points.   For instance, when two lines meet at 3 points,
>> one would get 2 gap polygons.
>> Given 2 zigzagging lines, how to write a function to return overlaps and
>> gaps is an interesting matter.
>> Regards,
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220502/0146b16f/attachment.htm>
