[postgis-users] Recursive query - ERROR: invalid memory alloc request size 1073741824
Shaozhong SHI shishaozhong at gmail.com
Sat May 7 17:50:34 PDT 2022
It is simply this recursive query.
Network Walking in PostGIS · Paul Ramsey (cleverelephant.ca)
<http://blog.cleverelephant.ca/2010/07/network-walking-in-postgis.html>
It is not the issue of forever/endless loop.
It runs at a point where it stops.
This error turned up.- ERROR:  invalid memory alloc request size 1073741824
Now, I have put the following statement in the loop
If (select count(*) <2500 from primary_watercourse) then
The idea is to skip over too big tables that are generated.
It keeps running at the moment.
This memory allocation issue was encountered before.
I think that it does not like large data sets.
Regards,
David
On Sun, 8 May 2022 at 00:59, Imre Samu <pella.samu at gmail.com> wrote:
> Hi David,
> > There is a loop of recursive query.  It runs at a point where it stops.
> >Can anyone provide pointers how to solve this problem or work around?
> Please share "this" recursive query;
> My guess:  Probably you have a "forever/endless loop" in your data; *so
> you have to LIMIT the recursive part ;*
> related links :
> 1.)  with limiting "depth"   ( where depth < 1000 )
> "Prevent infinite loop in recursive query in Postgresql"
> https://stackoverflow.com/questions/51025607/prevent-infinite-loop-in-recursive-query-in-postgresql
> 2.)  with LIMITING clause
> https://www.cybertec-postgresql.com/en/recursive-queries-postgresql/
> *"This example also demonstrates how an endless loop can be avoided with a
> LIMIT clause on the parent query."*
> Regards,
>   Imre
> Shaozhong SHI <shishaozhong at gmail.com> ezt írta (időpont: 2022. máj. 7.,
> Szo, 15:23):
>> 1073741824
>> Regards,
>> David
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220508/a8ddbafb/attachment.htm>
