[postgis-users] Configuration and performance of PostGIS
Shaozhong SHI
shishaozhong at gmail.com
Sat May 7 17:53:25 PDT 2022
Any further information on source and target?
Can I understand that source means startpoint of a line, and target means
an endpoint of a line?
Regards,
David
On Sat, 23 Apr 2022 at 13:29, Shaozhong SHI <shishaozhong at gmail.com> wrote:
> On Fri, 22 Apr 2022 at 22:14, Imre Samu <pella.samu at gmail.com> wrote:
>> > as St_intersects or recursive query used,
>> The other alternative ( ~ less efficient ) is using a “noded” network
>> table ( "edge_table" )
>> in the recursive query. ( and don't forget to add indexes to the
>> "source" and "target" columns )
>> WITH RECURSIVE walk_network(id, source, target, targetPoint) AS
>> (SELECT et.id,et.source,et.target,ST_EndPoint(the_geom) as targetPoint
>> FROM edge_table et WHERE et.id = *12*
>> UNION ALL
>> SELECT e.id, e.source, e.target ,ST_EndPoint(the_geom) as targetPoint
>> FROM edge_table e
>> , walk_network w
>> WHERE w.target = e.source
>> SELECT ST_AsText(ST_MakeLine(targetPoint))
>> FROM walk_network
>> | st_astext |
>> | LINESTRING(4 2,3 2,2 1,1 1,0 0) |
>> (1 row)
>> regards,
>> Imre
> I will have a close look.
> With the use of WHERE w.target = e.source, it probably avoided time
> consuming computation of ST_DWithin.
> Would WHERE w.target = e.source force the Postgres to use index-scan?
> If so, that might well be a more efficient way to do it.
> Regards,
> David
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220508/338f4b41/attachment.htm>
