[postgis-users] problem trying to compile postgis 3.2.1 on Mac arm64
Ben Madin
ben at ausvet.com.au
Mon May 9 01:21:50 PDT 2022
Hi all,
sorry to trouble you, but I'm trying to upgrade PostGIS 3.1.4 to 3.2.1 on
Apple Silicon and getting the error: 'Undefined symbols for architecture
arm64:' - the point in the build where it doesn't work is below (some of
it), and it seems to relate to the "FlatGeoBuf" lib.
I'm wondering if I have missed a particular configuration issue, I have
also included the output of the ./configure file
*Configure output*
PostGIS is now configured for arm-apple-darwin21.4.0
-------------- Compiler Info -------------
C compiler: gcc -std=gnu99 -g -O2 -fno-math-errno
-fno-signed-zeros -Wall
C++ compiler (FlatGeobuf): gcc -std=c++11 -x c++
CPPFLAGS: -I/usr/local/include
-I/usr/local/include/libxml2 -I/usr/local/include/json-c
-I/usr/local/include -DNDEBUG
LDFLAGS: -lm
SQL preprocessor: /usr/bin/cpp -traditional-cpp -w -P
-------------- Additional Info -------------
Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.10.2
GDAL config:
/Library/Frameworks/GDAL.framework/Programs/gdal-config
GDAL version: 3.4.3
PostgreSQL config: /usr/local/pgsql14.2/bin/pg_config
PostgreSQL version: PostgreSQL 14.2-av
PROJ4 version: 81
Libxml2 config: /usr/local/bin/xml2-config
Libxml2 version: 2.9.10
JSON-C support: yes
protobuf support: no
PCRE support: Version 1
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
Address Standardizer support: enabled
-------- Documentation Generation --------
xsltproc: /usr/local/bin/xsltproc
xsl style sheets:
dblatex:
convert:
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
*Output from the make script:*
gcc -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Werror=vla
-Werror=unguarded-availability-new -Wendif-labels
-Wmissing-format-attribute -Wformat-security -fno-strict-aliasing -fwrapv
-Wno-unused-command-line-argument -Wno-compound-token-split-by-macro -O2
-bundle -multiply_defined suppress -o postgis-3.so postgis_module.o
lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
lwgeom_inout.o lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o
lwgeom_box3d.o lwgeom_geos.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
lwgeom_geos_relatematch.o lwgeom_generate_grid.o lwgeom_export.o
lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o
lwgeom_dumppoints.o lwgeom_functions_lrs.o lwgeom_functions_temporal.o
lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
gserialized_gist_2d.o gserialized_gist_nd.o gserialized_supportfn.o
gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
brin_2d.o brin_nd.o brin_common.o gserialized_estimate.o geography_inout.o
geography_btree.o geography_centroid.o geography_measurement.o
geography_measurement_trees.o geometry_inout.o postgis_libprotobuf.o mvt.o
lwgeom_out_mvt.o geobuf.o lwgeom_out_geobuf.o lwgeom_out_geojson.o
flatgeobuf.o lwgeom_in_flatgeobuf.o lwgeom_out_flatgeobuf.o
postgis_legacy.o -lm ../deps/flatgeobuf/libflatgeobuf.la
../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
-L/usr/local/lib -lgeos_c -lproj -L/usr/local/lib -ljson-c
-L/usr/local/lib -lxml2 -lz -lpthread -liconv -lm -lm -bundle_loader
/usr/local/pgsql14.2/bin/postgres
ld: warning: dylib (/usr/local/lib/libjson-c.dylib) was built for newer
macOS version (12.1) than being linked (12.0)
Undefined symbols for architecture arm64:
"std::__1::__shared_weak_count::__get_deleter(std::type_info const&)
const", referenced from:
vtable for std::__1::__shared_ptr_emplace<FeatureItem,
std::__1::allocator<FeatureItem> > in libflatgeobuf.la(flatgeobuf_c.o)
"std::__1::__vector_base_common<true>::__throw_length_error() const",
referenced from:
std::__1::__vector_base<flatbuffers::Offset<FlatGeobuf::Column>,
std::__1::allocator<flatbuffers::Offset<FlatGeobuf::Column> >
>::__throw_length_error() const in libflatgeobuf.la(flatgeobuf_c.o)
cheers
Ben
[image: Ausvet Logo] <https://www.ausvet.com.au/>
Dr Ben Madin
BVMS MVPHMgmt PhD MANZCVS GAICD
Managing Director
Mobile:
+61 448 887 220 <+61448887220>
E-mail:
Website:
www.ausvet.com.au
Skype: benmadin
Address:
5 Shuffrey Street
Fremantle, WA 6160
Australia
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220509/e26b7ccc/attachment.htm>
